Spiking to 19.5PSI...No CEL Though????
Old Oct 22, 2004 | 09:01 AM
Paperchasin's Avatar
Car Info: Comeback?
A turbo back exhaust will cause boost creep...once u boost too high, u will hit the cutoff, which is why ur boost drops...its a serious problem...do a search on boost creep and u will see wut i mean...
Old Oct 22, 2004 | 01:22 PM
Car Info: Comeback?
I see....maybe u just have a bad gauge??
Old Oct 23, 2004 | 10:46 PM
bassplayrr's Avatar
Exactly... can you feel the spike and subsequent leveling off? If not I would wager it's a bad gauge. If you can feel it, it may also be a bad boost solanoid. That would be easy to diagnose as you can just swap one from a fellow suby in like 30 seconds, try it out, and quickly swap back. There's no good way that I know of for detecting an ECU reflash, but you may want to try resetting your ECU just to have a clean slate to start from with your future diagnosis.
-Chris
Old Dec 30, 2004 | 02:04 PM
EROCK's Avatar
Car Info: 04 STi
Originally Posted by polyol
I know what boost creep is...I have it on my GSX. This is not boost creep...its a boost spike. Creep is when you are at WOT and your PSI goes up and up and up till you hit fuel cut. Mine hits high and falls off and stays at 16 psi or so. That’s spiking.
I have not hit cutoff...you know when you hit cutoff. Cutoff will be somewhat violent, not gradual...at least it is in my GSX.
I need to know how I would tell if it has a modified ECU? I have a feeling that it is modified because no CEL and no fuel cutoff with spiking to 19.5psi.
I had the same issue once....spiking at 19.5psi and never got a CEL and no fuel cutoff. In my experience, fuel cut off happened when you stay above 16.5psi for about 2 seconds. From there, you'll get the CEL and flashing cruise control light. For example, full throttle in 5th gear when it's cold outside would always get me fuel cutoff.
Old Dec 30, 2004 | 04:22 PM
apssti's Avatar
mine did the same thing, u need some engine managment or turbo xs fuel cut defender!!! will solve the problem.
Old Dec 30, 2004 | 06:16 PM
Egan's Avatar
Mine does this with an ECUtek reflash and 3" TBE. I have two boost gauges (one GReddy dial gauge that is electronic and one PSI3 data display that reads directly form the ECU) and they both reported the high boost. In fact my PSI3 recorded 20 psi. This only happens at WOT accelerating onto the freeway when it is cold out (<40 F). The spike is momentary and the ECU immediatley adjusts. No CEL's have ever gone off and the engine is running fine.
I believe it is just a matter of the turbo getting ahead of the ECU for an instant.
scoobiesleeper2
Mar 30, 2006 12:49 PM
2Quick
Sep 11, 2005 09:53 AM
WRXWagon203
Jul 14, 2004 02:10 PM
minisiu
Jan 11, 2004 03:59 PM
StlWrx
Dec 8, 2002 12:41 PM
