oil loss
Old Jan 8, 2005 | 10:48 PM
pimpsti's Avatar
Car Info: 05 PSM STi
oil loss
Hey was wondering if i got a bum motor or is this normal? i have 2800 miles on my 05 STi and i checked the oil today and noticed it was a little more than half a quart low???? is this normal for the motor since it's just breaking in? Does anyone else have to top off there's between oil changes?
Old Jan 9, 2005 | 01:52 AM
Group B's Avatar
Dahveed aka Robin Hood
I have 14k miles and still have to top-off in between oil changes, its normal.
Old Jan 9, 2005 | 10:16 AM
pimpsti's Avatar
Smile
Thanks Group B.....i was wondering if i was needing to drop it off to the dealer with a menacing note...
Old Jan 9, 2005 | 01:56 PM
If you're burning oil, they should give you a compression check under warranty just to be sure, but at this point I wouldn't worry. Less than a quart between oil changes isn't a problem.
Old Jan 10, 2005 | 11:33 PM
gdogg's Avatar
Car Info: 1973 Huevo Ranchero
i burn almost a quart with regular oil between changes. i drive hard and plenty and often. and stop and go traffic.(i live in hawaii)
with synthetic i have consistently burned less(about half a quart consistently over 3 oil changes)
Old Feb 25, 2005 | 05:17 PM
1sti36t's Avatar
Too much oil loss
I have an 04 STI with about 15k. In the last 3000 miles I have had to add 3 quarts!? I have no leaks and I do not notice any white, black, or blue smoke. I did notice a little oil dusted on my intake hoses but none sitting in my fmic. If any one has any info, please help. -Confused?
Old Feb 25, 2005 | 06:54 PM
gdogg's Avatar
just out of crazy curiosity... any power loss? did you check your coolant? what color is your oil?(fingers crossed) 3 quarts is excessive....
Old Feb 25, 2005 | 08:08 PM
tim's Avatar
tim
Using a good synthetic oil should help a little as they are far more resistant to heat. You will still loose some, but not as much. I know that a lot of people advise against it, but I have always used slightly heaver oils in all of my turbo cars. I have had three of them now, and it seems to protect the engine a little better. I never use anything lighter than 5w-40. Castrol Syntec has a really good 5w-50.
Old Feb 26, 2005 | 08:28 PM
1sti36t's Avatar
No power loss
No power loss, coolant is clean, oil is clean, and i use redline synthetic oil. I appreciate the help.
Snoshado
Forester General
Sep 9, 2012 09:51 AM
slipstreamxk1
Jun 29, 2006 10:28 AM
Diverdave
Jan 4, 2005 04:39 PM
mmboost
Jan 9, 2004 11:25 PM
Blue-Adept
27
Nov 15, 2003 11:19 PM
