Diagnosis Request: Tranny doesn't catch beyond 1st
Old Jun 23, 2013 | 09:11 PM
JooseyJeff's Avatar
Car Info: 06 TRD Tacoma
So I was driving tonight, shifting into 5th from 6th off the freeway. the shift **** goes all the way vertical, doesn't catch and revs drop to idle. I hit the hazards and pull to the side. Fortunately I was close to home, and when i tried to get in gear the only gear I was able to get into was 1st. Slowly drove home and am extremely concerned.
Shift **** goes up and down freely without catching in any gear, what's the issue? Do I need a new tranny? New syncros? New ****? **** I don't knwo but I'm worried. Fortunately I have a motorcycle so I can still get around but I would appreciate any suggestions.
Old Jun 23, 2013 | 09:13 PM
jdblock's Avatar
Car Info: 2004 STI
Check your shift linkage under the car.
Old Jun 23, 2013 | 09:18 PM
pho_shizzle's Avatar
Car Info: MY00 GC6 BRP
Your u-joint linkage (front part of shifter linkage) on your shifter may be in bad condition, or got spontaneously disconnected. Look around the area for clues of what could be loose, or wrong. I don't think your transmission can give out just like that, according to those symptoms. I highly believe it has something to do with/around the shifter assembly.
Old Jun 23, 2013 | 09:35 PM
wrxfreak's Avatar
Car Info: 2003 WRX
it might be a ghost or gnomes.
Old Jun 24, 2013 | 08:11 AM
JooseyJeff's Avatar
Makes sense, and I sure as hell am going to take a closer look myself before taking the car to a mechanic. Unfortunately this happened about 100 miles from my house and I work all the time so taking a look is much easier said than done
Old Jun 24, 2013 | 12:46 PM
Well if you are efficient enough with your time, I say it would only take 15-20 mins max just to take a look. Finding the floor jack, then jacking up the car, and crawling under, taking a look at where the shifter linkage is. Take a couple of pictures (clear pictures, use flash if you have to) then get out and put it away. Post up the high res pictures for us to look at when you have time later after work.
Old Jun 24, 2013 | 03:09 PM
jdblock's Avatar
Car Info: 2004 STI
At least its not goblins or Elvis.
Old Jun 24, 2013 | 03:20 PM
Brfatal's Avatar
Technical Know-It-All
Car Info: '02 WRX + '15 WRX
Elvis happened to my car once. It's been in the shop for 2 years consecutively since.
Old Jun 24, 2013 | 04:06 PM
jdblock's Avatar
Car Info: 2004 STI
You had to step on his blue suede shoes....tsk....tsk.
Old Jun 25, 2013 | 10:27 AM
JooseyJeff's Avatar
If I were to guess, I'd say it's probably an issue with 35035A in the image below:
Old Jun 25, 2013 | 11:47 AM
^ I hardly doubt that, but that is easy to check and is INside the cabin, not under the car.
We are talking more about 35046, or around 35035 area. Give it a look and let us know.
Old Jul 2, 2013 | 10:43 AM
JooseyJeff's Avatar
So I got a chance to stop by the car and take a look under the shift boot. You were close, Pho Shizzle. The ball that fits in the cup (35035) at the bottom of the shift lever had popped out and was just sitting on the carpeting to the side of the cup. I was able to lift it and push it back in place in the cup and can probably drive it as long as I don't do any hard shifting. However, I'm not sure what's needed to get the ball to stay in place..I'm assuming some sort of gasket?
Old Jul 2, 2013 | 12:32 PM
You mean the front shifter bushing popped out? There is a directional flat washer and a nut that should hold the bushing in place.
Old Jul 2, 2013 | 03:26 PM
JooseyJeff's Avatar
that directional flat washer and nut were nowhere to be found. They seem to have just disappeared, so maybe it is a ghost or gnomes..
Old Jul 2, 2013 | 04:47 PM
You can see it on the diagram, 35082B and 023508(3) , you can probably put some thread locker on the bolt when you replace those parts.
neokai
Jul 8, 2005 01:55 PM
Ex-ricer
Feb 4, 2005 12:49 PM
Subaruski42o
Jul 31, 2004 08:48 PM
Zora
Feb 14, 2004 09:31 PM
IANOC
Sep 13, 2003 02:56 AM
