Cobb Stage 2 91oct lwg Map and lots'o "Det"
Old Aug 19, 2004 | 12:20 AM
Mach5WRX's Avatar
Angry Dan
Car Info: 05 Evo VIII
http://www.wrxforum.com/cgi-bin/ulti...c;f=8;t=000363
Called Cobb 17-18ish psi is just fine.
Any thoughts?
Old Aug 19, 2004 | 01:01 AM
RoadSpike's Avatar
First I can't make boost, now I'm making too much.
Any thoughts?
Boost creep i wager.
It says you have a catback but do you have the turbo port and polished?
Old Aug 19, 2004 | 01:50 PM
Mach5WRX's Avatar
Angry Dan
It's not boost creep.
Old Aug 19, 2004 | 04:20 PM
v rod's Avatar
Car Info: Real Slow
dan,
maybe it's time to port the exhaust housing!
anyone done this with the ap?
Old Aug 19, 2004 | 04:32 PM
Mach5WRX's Avatar
Angry Dan
Originally Posted by v rod
dan,
Ed it's not creep.....Pat and I think it's because I had around 450lbs more in the car than usually.( I had pat and all his bags in the car, more load on the engine) I'm going to do some Delta Dash logs ASAP and find out whats going on.
Old Aug 19, 2004 | 06:49 PM
RoadSpike's Avatar
Good thoughts.
Did you try the different kinds of gas?
When i was helping a buddy we switched from 76 to chevron to test for pinging and det. The chevron ping'ed less but in the end he switched back to 76 when he got an upgraded map off the internet. No more det. since.
srbaugust
15
Jun 2, 2013 02:02 AM
chimchimm5
Sep 17, 2011 06:05 PM
lburrrna
Jun 28, 2006 05:26 PM
wrx10404
Jun 7, 2004 06:14 PM
Chibby Goku
Jun 25, 2003 05:13 PM
