WRX cooling system problem HELP!!!
Old May 21, 2012 | 10:18 AM
prlbluwrx's Avatar
Car Info: 2015 WRX
I have a 2005 WRX 2.0L 115,000 miles. Mods up/down pipe(catless), accessport, short ram intake, gfb bov, and spt catback. My problem, Coolant is disappearing in just 2 days with no signs of a leak. Here is a brief summery of what is happening. last week I was driving home running my a/c and my temp spiked up and almost went into the red. I shut the a/c off and cranked up the heater. The car proceeded to drop right back to the normal spot halfway between the two lines. when I got home I noticed that my coolant bottle was empty so I filled it and ran the car for awhile with no problems. 2 days later. Car is driving great no more over heating problems. Great news. I pop the hood to check everything out and the coolant bottle is almost empty again. I refill it again. 2 days later I check the coolant tank again its low again. I did notice a couple of times a little smoke coming from the turbo area of the engine bay, not if that is related or not. PLEASE HELP me. Any thoughts questions or comments are appreciated.
Old May 21, 2012 | 10:36 PM
strider327's Avatar
Car Info: 2005 WRX
Sounds like a headgasket problem
Old May 22, 2012 | 06:13 PM
jam007's Avatar
Did you try a coolant system pressure test? Milky oil? White smoke out of exhaust?
Old May 22, 2012 | 07:34 PM
831subaru's Avatar
heater core might be cracked located inside the middle of the dash if its heater core you should see white smoke inside the car when heater is on full blast, coolant ports in the heads might be crack, check coolant system pressure, check your oil cooler hoses if they aint cracked or leaking on the crossover running under intake manifold other than that look for dry coolant clean it and check it again later
Old May 25, 2012 | 07:19 PM
jam007's Avatar
Or the crush washers on the turbo for the coolant are leaking by, I did have this happen before.
Dre2932
Mar 14, 2009 09:58 AM
Dre2932
Mar 14, 2009 07:48 AM
subywrxtuner696
Aug 25, 2007 02:56 PM
nautic1601
Sep 26, 2004 04:33 PM
Arkangelscooby
21
Aug 7, 2003 05:37 PM
