Major (WRX) cooling problem
Old Jul 25, 2007 | 05:23 PM
subywrxtuner696's Avatar
Car Info: 02 wrx silver
Guys I have a huge problem I cant figure out! I drive a 2002 wrx that has a stock engine. I was driving down the road and I found that my temperature gauge started to rise really fast!! So I drove slow home and installed a new thermostat, still didn't help. My symptoms are as follow: Overheating when driving down the road watching temperature gauge rise quick, when i rev my engine, it goes up fast! When the gauge is up close to red, my radiator is ice cold, however, it is very hott on the top of it. When the engine is not started but the key is on, both of my fans turn on and off and I hear a bunch of switches flip on. Could this be a temperature gauge milfunction, water pump, radiator, fan sensor or what. Any help is appreciated, my car is on jack stands and I dont have another car
Old Jul 26, 2007 | 09:27 AM
symby's Avatar
Car Info: 2002 Impreza WRX
Have you tried burping the coolant system? I've heard bubbles in there can cause the symptoms you are seeing.
Old Jul 26, 2007 | 09:30 AM
midnitewrx's Avatar
or plugged radiator ??? top side is hot when it enters bottom ice cold? dont think its circulating
Old Jul 26, 2007 | 09:50 PM
cowg's Avatar
Car Info: 07 subaru wrx
See if you can borrow one of those Laser? thermometers, the kind you point at a place and it gives you a reading. I've used them on motorcycle engines for overheat problems and it made trouble shooting much easier.
Old Jul 31, 2007 | 10:18 AM
whtwrx1991's Avatar
Car Info: 2005 STI
sounds like you have "vapor" lock. when you fill the radiator, you add cooland, start the car until it warms up, check fluid, add fluid until the system is full. You can assist this by "pumping" your top radiator hose. Caution: don't pump your hose to much!!!
Old Aug 25, 2007 | 02:56 PM
mattsn0w's Avatar
make sure to use the subaru coolant conditioner as well. it helps protect against nasty build up in the block.
prlbluwrx
May 25, 2012 07:19 PM
Max419
Jan 25, 2007 08:26 AM
DubVee
Dec 3, 2003 12:52 PM
AzN121184
50
Jun 30, 2003 12:22 AM
WRXs2Fast4U
81
Mar 9, 2003 05:12 PM
