Weird Sound After Uppipe Install
Old Jan 21, 2005 | 10:52 PM
Nate0125RS's Avatar
Car Info: '03 Silver WRX
I think that bracket it for the larger STI intercooler, at least that's what I've been told before. Either way, I have the same bracket that's not holding anything, and no problems. It's funny though, because I did notice that same empty bracket after my uppipe install as well.
Old Jan 22, 2005 | 12:27 AM
WRX2ndregime's Avatar
Car Info: 2005blackwrx5spd
yeah, my bracket is holding my larger STI intercooler, haha
Old Jan 25, 2005 | 02:29 PM
njc200's Avatar
Oh, haha, thanks guys
Old Jan 30, 2005 | 01:54 PM
SR-71WRX's Avatar
Car Info: 2003 BMP WRX
Did you ever tighten up those missing bolts?
Old Jan 30, 2005 | 08:14 PM
DrD's Avatar
DrD
Car Info: 2012 Legacy 2.5GT-L
sounds like it could be the wastegate - some people have found adjusting the shaft which controls it to help.
Old Jan 30, 2005 | 10:01 PM
iLoqin's Avatar
Car Info: Nadda
Or it can be the actual turbo in your pipe, I remember when I thought it was leaking and I had someone in gruppe-s listen to it, he sorta laughed and said it was normal =P.
Old Feb 2, 2005 | 08:24 AM
njc200's Avatar
You can adjust the wastegate on a stock DP?
Old Feb 2, 2005 | 09:56 AM
yeah, I'm to the point now I don't really care if it rattles, all I know is that's the sound of someone losing very badly.
Old Feb 4, 2005 | 06:44 PM
DrD's Avatar
DrD
it's on the stock turbo - you remove the turbo heatshield, take the c-clip off the shaft to the wastegate, and turn it towards you a little bit (to tighten it up), put the c-clip back on and see if the noise is still there - repeat until it's gone (or until it's clear that isn't the problem) then put the heatshield back on.
Old Feb 5, 2005 | 12:06 PM
se0ul's Avatar
Car Info: 04 wrx, 05 Elise, 14 Impreza, 17 brz coming soon
im not sure if its the same problem as mine..but after around 4k rpm and going into full boost, i had this like.. "wind sucking in/fluttering sound" it was like that for a long time until i decided to put my stock uppipe back on. when i did i noticed the top bolts on the uppipe were not tight. after replacing the uppipe gaskets and tightening the bolts, the sound went away and car ran A Lot smoother.. i also had another one of these "wind sucking" sounds before except it was more criticial. the problem was the silicon ic hose that was connected to the turbo. the heat of the turbo and the tightness of the clamp wore out my ic hose and so it leaked.
i<3dirt
Oct 20, 2014 10:26 AM
starrman85
Oct 31, 2010 12:09 PM
05_WRex
Nov 26, 2007 06:21 PM
Zoeb2s
Jun 13, 2003 05:58 PM
ges311
Apr 3, 2003 07:00 PM
