Turbo longevity?
Old Jul 25, 2003 | 01:32 AM
supra_man's Avatar
well if your not going to race then the turbo will last till about 80k before you should rebuild it. but you dont have to. For your second q, you dont need the guage unless your a racer. The guage is there to tell you if somethings wrong from all the pounding of the motor.But you not going to pound it right? peace
Old Jul 25, 2003 | 10:13 AM
andyhidley's Avatar
Car Info: 2002 WRX
80K?? I bet it will last well into 100K with oil changes and proper cool down, i.e. no cokeing. Remember he said normal driving..
The boost guage is what a vacuume guage is for a N/A car.
It reads how much vacuume is in your intake then as you open the throttle the intake becomes pressurized.
Vacuume guage reads from atmospheric pressure down into negative. 0 thru -10 (example only)
Boost guage reads from positive pressure down to zero(atmospheric) and then down into negative. +10 thru -10 (example only
Is a boost guage usefull?? It is if you watch it!!! It will tell you of many engine problems. It will tell you if your over boosting because you modified something to much. So if you plan on adding horsepower than that is an ideal way to monitor that you are staying within safe limits.
Old Jul 30, 2003 | 08:55 AM
Racer's Avatar
Car Info: '04 WRX Wagon - Java Black
Another related question:
As a new WRX owner I also worry about Turbo longevity. In the old days you were required to let the engine idle for about 30 sec - a few minutes (depending on how hard the car was just used) to help cool the turbo and prevent coking.
It seems manufacturers are getting away from that. My wives Audi 1.8T has no such warnings by either the dealer or in the owners manual. To my suprise, no warnings were in my Subaru manual or from my dealer.
So. Is it no longer a concern? Are the motors built to cycle oil through the Turbo even if shut down quickly? Will Mobil 1 provide better protection than conventional oils?
Most of my driving is highway mileage. Any guesses on how that may impact Turbo longevity?
Help!
Old Jul 30, 2003 | 09:07 AM
teiva-boy's Avatar
Car Info: Boosted Geo Prizm
The stock WRX turbo is oil AND water cooled. There is no need for a cool down period on any of the WRX turbos including the IHI line of upgraded turbo's. When you turn off the car, coolant is passing through it still.
Old Jul 30, 2003 | 09:50 PM
supra_man's Avatar
But after a nite of racing it wont hurt to let your car cool for a little while.peace.
ShaneWRX
Oct 3, 2006 07:17 AM
ImpWrx007
Mar 23, 2006 12:04 PM
Bobert540
Mar 17, 2005 06:53 PM
wrxchris
Aug 10, 2004 08:15 PM
singsing
May 24, 2003 03:19 AM
