01 2.5RS...Motor longevity??
Old Mar 15, 2005 | 08:35 PM
Bobert540's Avatar
Car Info: 2001 Subaru Impreza 2.5RS Silver
I am looking at a higher mileage subaru right now....how long do the 2.5 engines last? current mileage is 98k
thanks!
Old Mar 16, 2005 | 01:09 AM
Longer than that. The SOHC engines have no signifcantly common failure points. I'm at 80k on my '01, and it's had no issues whatsoever.
Old Mar 16, 2005 | 10:16 AM
poormansporsche's Avatar
Car Info: 2.5RS STI swapped
I've had to RS's. First one I drove to 45k miles with only one problem. Something got squeaky after I pully my friends Jeep Grand Cherroke out of the mud. I kind of had some fun too while I was out there My second RS has over 80k and runs really solid still. Previous owner only replaced wheel bearings.
cheers
garrett
Old Mar 17, 2005 | 06:24 PM
AWDimprezaL's Avatar
make sure head gaskets were done (sohcs leak externally,from the bottom unlike DOHCS leak internally) also make sure you start it when its cold, make sure it doesnt have a ton of piston slap...owtherwise its good to go...98K is nothing on a maintained suby engine
Old Mar 17, 2005 | 06:36 PM
No need to "make sure they're done." As long as the motor had the original coolant in it or the additive during later flushes, it's fine. If it's not losing coolant you don't have an issue.
Old Mar 17, 2005 | 06:53 PM
Unhappy
you are right ban suvs...but working at a subaru dealer, we are swamped with sohc head gasket jobs, subaru refuses to use the updated steel DOHC head gasket, so they keep blowing...but if they arent leaking, dont worry about it
ShaneWRX
Oct 3, 2006 07:17 AM
ImpWrx007
Mar 23, 2006 12:04 PM
wrxchris
Aug 10, 2004 08:15 PM
jamester
Jul 30, 2003 09:50 PM
