STi top mount?
Old Aug 16, 2007 | 11:22 PM
-WickedRex-'s Avatar
Car Info: 2002 Impreza WRX
STi top mount?
i want to get a STi top mount for my 02' WRX. I want it to be a direct fit only. i am looking to get the best t/m so i naturally want to get the biggest. i heard the jdm ver. 7 t/m is larger than my original choice of the usdm 04/05 STi t/m. i also noticed that there is a jdm spec C that is still a bolt on. any help on the differences and preferences. also wonder if air splitter will fit either model.
Old Aug 17, 2007 | 09:47 PM
taerron's Avatar
why stop at an sti top moun? there are plenty of ic's out there that will out perform that intercooler.
Old Aug 22, 2007 | 10:29 AM
STi-owns-evo's Avatar
Car Info: '02 PSM WRX
The bracket that the stock IC mounts to on the passenger side, has an extra threaded hole. That's for the V7 STi IC. They're pretty good, and you can't get much of a better fit than stock. Expensive and hard to find though.
I'm not sure about the Spec C, as I don't know if it'd use the same mounting points. I think with any bigger core, you need to get a different splitter and, might as well get a STi scoop. However, for the price of a V7 STi, you can easily find a better TMIC that's an aftermarket, might need to adjust your a/c line, but after that it'll have a bigger core and cool better for cheaper.
Old Aug 22, 2007 | 10:30 AM
SubyN00by's Avatar
What other mods do you have? If you are still with stock everything else, you won't really see much of a difference between sti TMIC and an aftermarket one...
Old Sep 8, 2007 | 06:02 AM
taerron's Avatar
+1 from above
if you are in stock form still, don't worry about getting a bigger IC. if you are getting your car tuned, bar and plate would be preferable, but anything bigger than the stock one will help.
polishsti
Jun 16, 2010 07:02 PM
Bro-Gnar
Apr 21, 2007 06:21 PM
Lazyboy
Dec 8, 2006 08:06 AM
aznsensation18
Jun 24, 2005 02:33 PM
Antonio85
Jun 24, 2005 10:24 AM
