Spool sound
Old Jan 30, 2004 | 07:50 AM
wrx10404's Avatar
Car Info: 04' wrx
Re: Spool sound
Originally posted by V8haha
Will adding a cold air intake make the spool sound greater. I have an uppipe and downpipe already.
yup!
Old Jan 30, 2004 | 01:53 PM
qwk_wrx's Avatar
Car Info: 05' Evo 8
i would go short ram...cold air makes your A/F ratio too rich....
or if you have not done the resonator mod that helps too....
Old Jan 30, 2004 | 10:05 PM
awns729's Avatar
Car Info: want a WRX
really?
Old Jan 30, 2004 | 10:17 PM
TurnWRX's Avatar
Re: Spool sound
Pull one of the plugs out of the firewall near the brake pedal. You'll hear the whistle much louder as well.
Old Jan 31, 2004 | 11:01 AM
sKOOTeR WRX's Avatar
Car Info: WR Blue WRX
From what I have read a most of the deigns of the CAI will cause a lean condition because the MAF will sense more air that is truly passing by it. Normally it doesn't change the mixture to much but I guess the most change will occur in cylinder #3.
The design of the stock MAF location is after a right turn which results in different pressures of air on the inside of the curve vs the outside.
Old Jan 31, 2004 | 11:11 AM
awns729's Avatar
I think the MAF senses more air and then the ECU adds more fuel to compensate for the air-an intake does nothing
namitherussian
20
Dec 23, 2003 05:47 AM
BLOWN
Nov 9, 2003 03:48 PM
Chris04WRX
Jul 29, 2003 07:28 PM
rex1308
May 24, 2003 01:03 AM
kongzilla
Jan 1, 2003 07:57 PM
