Re-Post: Coolant Loss Help
Old Dec 5, 2005 | 08:42 PM
robb's Avatar
Car Info: 2003 Silver WRX Sedan, 1982 Corvette Collectors Ed.
Hey Guys,
I posted this in the bay areas thread and thought I should put it here.
I recently put an UP and DP on my '03 WRX (45K miles). All of the coolant (return and supply) lines are properly installed (reusing the spring clips) and are not leaking. There is no steam or visible venting, the boost seems to be running fine (I do not have a gague) and power is what is to be expected. The tempurature is remaining the usual spot on the gague (even under hard driving) but it has been cold here (snowing and shizz).
Anyway, the coolant in the clear tank is dropping slowly. It goes from full to low in about 400 miles. I had the system flushed and there is no air in the system as far as I can tell....
I do smell a light coolant odor on occasion and the usual stank from no cats...
Do you have any thoughts on what may be causing this? Is it possible to have this leak and not have it be visible? Could it be a head gasket leak minor enough that it burns off before I can see it or a leak internal to the turbo?
Thanks for the help...
Old Dec 11, 2005 | 06:58 AM
Donkey's Avatar
Car Info: 02' WRX
Originally Posted by robb
Hey Guys,
Are you using a 1.3 bar radiator cap?The stock radiator sucks and when you switch the stock 1.1 bar cap with a 1.3bar cap you start getting cooling pushing out from the top and bottom radiator caps.The stock radiator just can't handle the extra 3-4psi of pressure from the 1.3bar cap.
RoadTrippin
Sep 10, 2008 05:30 PM
prspect06
May 5, 2006 12:20 PM
robb
Nov 30, 2005 09:43 PM
WindCloud
Aug 5, 2004 01:08 AM
mmboost
Jan 9, 2004 11:25 PM
