no boost.
Old Apr 30, 2004 | 03:19 PM
555sube's Avatar
no boost.
hey i visit here all the time but i rarely post. So let me introduce my self. Im edgar, and i drive a 02 wrx. My problem is that i had a boost problem since installing my uppipe and checked my hoses piping and everything, so i came to the conclusion that it was a gasket. After checking the bottom gasket i found it to be cracked. So i obviously thought the problem was fixed. But it isnt. My boost still wont go over .5 bar and i have no idea what else it could be. I revised all the piping, hoses, and clamps while nothing looks damaged or loose. Does anyone have any suggestions? thanks alot.
Old Apr 30, 2004 | 10:17 PM
mexicanpizza's Avatar
Car Info: MMVI AW WRX STI
.5 bar is approximately WG pressure. I would check all the vacuum lines to the turbo, and make sure none of the restrictors are melted shut.
Your factory boost controller could be stuck shut also.
Old May 1, 2004 | 03:17 AM
BrianH's Avatar
Car Info: NONE
ANY cel's?
Old May 1, 2004 | 05:00 AM
Wingless Wonder's Avatar
Origami posted by 555sube
Check the factory boost control vacuum hoses and make certain the tiny bleed orifice is still in the correct hose.
Old May 1, 2004 | 01:38 PM
555sube's Avatar
see, ichecked the hoses soon after the problem arose and i checked the hose comming off the turbo inlet to inspect the orifice and there was none. So i bought an orifice and put it inside the hose i was told it was supposed to be found in. Was the info given to me correct? As soon as i get home ill check the hoses once more. thanks for your help pps.
Old May 2, 2004 | 11:27 AM
so there is no leaks from teh up pipe correct?
Old May 2, 2004 | 01:50 PM
555sube's Avatar
correct, thers is no longer a leak in the up pipe.
Old May 2, 2004 | 07:45 PM
1/500yellowwrx's Avatar
Do you hear any whistling noses. I had the same problem after my install. Turned out i left a hose off the bov. I had no boost just like you and the car ran so bad. After 5 mins. of just finding the nose i found the problem. If any hose is off it will cause a problem.
yzercyber
Aug 12, 2005 03:42 PM
Astacun1
Jun 28, 2003 03:12 PM
mattr762
Apr 18, 2003 09:12 AM
ShokWaveRider
Feb 21, 2003 06:14 AM
XwrxX
Dec 17, 2002 07:14 AM
