boosting low
Old Dec 11, 2003 | 08:02 PM
Wingless Wonder's Avatar
Origami posted by Tchsssss
does anyone have a closeup picture or diagram of the actuator and surrounding hoses? i want to make sure i didnt foul anything up.
i went for a test drive just now... and im boosting only 8psi in all gears.
Check this install of an MBC on ScoobyMods.com. By reversing the order of installation, you might be able to figure out how to put everything back. Also, one of your factory boost control lines contains a small restrictor bleed fitting, usually made out of brass with a tiny hole drilled through the center. This restrictor bleed is inserted inside one of the factory vacuum lines and is easily overlooked. If the line with the restrictor bleed is not used, or if the line is replaced in the wrong position, boost will not exceed what you are presently seeing.
EDIT: amended 'bleed' fitting to restrictor bleed'.
Old Mar 9, 2004 | 04:42 PM
DriftinS14's Avatar
Car Info: 02 WRX, 06 A3
Im missing this part too. Didnt realize I needed it after I did my MBC install. Do you guys have a part# so I can order it from the dealer?
Thanks guys!
_justin
wonton2049
Jan 1, 2004 09:33 PM
Chibby Goku
Sep 4, 2003 09:14 PM
stealth-wrx
Apr 29, 2003 10:20 AM
DriftinS14
20
Mar 8, 2003 12:48 AM
br0kwrx
Feb 10, 2003 12:41 PM
