Boosting problem
Old Dec 30, 2003 | 03:12 PM
wonton2049's Avatar
Car Info: 2005 STI
Boosting problem
Hi everyone. i have a problem with my wrx. i bought it used and it has problems with the boost. i have the 3 gauge cluster where the clock belongs so the boost gauge reads Mpa's instead of PSi. i have major turbo lag and in second or third gear, i can hit .7 Mpa but it drops right away. isnt the stock wrx suppose to have a peak boost of 14.5 or somthing (about .1 mpa)? my mechanic told me that maybe the previous owner had a boost controller and took it out so it might be messed up. what do you guys think could be wrong? i only have a hks up pipe down pipe and cat back. thanks.
Old Dec 30, 2003 | 07:17 PM
wonton2049's Avatar
Car Info: 2005 STI
umm.... i tried reseting it but it didnt work. there is still major turbo lag. ive been trying to drive it to see if the ecu resets itself but still nothing. thanks for the help so far. more ideas would be appreciated. oh yeah, i bought it with this problem too. the car was pretty cheap.
Old Dec 30, 2003 | 11:40 PM
Max Xevious's Avatar
BanHammer™
Car Info: 2014 Forester XT
hopefully there is nothing major wrong with your car. Anything new with it ?
Old Dec 31, 2003 | 07:20 AM
mmboost's Avatar
Well... lets assume for the second you're reading the gauge wrong. First off, you mean 0.07 MPa, not 0.7 right And lets assume for the second that your actually boosting closer to 0.5MPa. This could be an indicator that you're running on the wastegate only. Perhaps the previous owner took his boost controller out and did not put the boost lines back properly.
IIRC, there should be a line that goes from the compressor to the wastegate actuator. In the middle of that like is a T which leads off to the factory boost controller. Also make sure that and other lines are secure, not cracked, etc.
jason
Old Jan 1, 2004 | 12:43 AM
mmboost's Avatar
Stock boost, by Subaru's words, is 14.2psi. This is from at least 3rd gear on, if not in 2nd as well. Max boost in1st gear is appearantly ~7psi
jason
Old Jan 1, 2004 | 04:41 PM
kspek's Avatar
Car Info: non subarus
1st and 2nd gear will mostly not hit full boost and especially using the facotry boost controller. check the hoses to see if theres any leaks
Old Jan 1, 2004 | 07:06 PM
mexicanpizza's Avatar
Car Info: MMVI AW WRX STI
I would also check that the boost lines are configured properly, and if they are, that the inline restrictor is not melted shut. That will give you wastegate boost ~ 7psi
-=eric
Old Jan 1, 2004 | 09:33 PM
Speed Element's Avatar
Former Sponsor
Car Info: Evo X, 04 STI, 335i, Fit
Like everyone else above has said I would check that the vacuum lines are connected correctly as it does sound like you are running off the wastegate.
Mike
(510) 487-4447
www.mpjperformance.com
www.gb-motorsports.com
Tchsssss
May 3, 2004 01:38 PM
Chibby Goku
Sep 4, 2003 09:14 PM
stealth-wrx
Apr 29, 2003 10:20 AM
DriftinS14
20
Mar 8, 2003 12:48 AM
br0kwrx
Feb 10, 2003 12:41 PM
