Loss of power
Old Aug 5, 2012 | 03:52 PM
wrxmo's Avatar
Loss of power
T spools fine and seems normal up untill 4k then it sounds like my gears are winding and it a like I just maintain the same amount of power almost like there's a block . Any ideas ??? I do have a cylinder one misfire other then that it's fine
Old Aug 5, 2012 | 04:14 PM
johndabrit's Avatar
Da Brit.
Are you running an aftermarket flywheel?
Are you tuned?
Does the car recover at any point higher in the rpm after the occurrence at 4k or can you not get there?
Does it always happen? Or only on WOT?
First thing to do is Disconnect battery then clean your maf. A flat spot may have developed. Could be fuel cut. How many miles are on your fuel pump? When was your fuel filter changed? If that doesn't fix it? Take it to a subaru specialist for a data log.
Old Aug 7, 2012 | 08:41 AM
wrxmo's Avatar
Pretty much everything on the car stock except that has a new 2.0 short block with less than 10,000 miles and same with the trans the trans been updated to a straight cut five-speed and same as the clutch. I am running on a cylinder one miss fire because of the coil pack the plugs were just updated so I know it's not the plugs. And I also know my Turbo seal is going . but as far as the problem it will go up to about four grand that it seems like it's losing boost. but the pressure is consistent at 15 psi.
Old Aug 8, 2012 | 09:48 PM
johndabrit's Avatar
Da Brit.
Could be a clogged cat.
Could be that your coil pack gave out finally. How is the idle? Could be boost leak.
Old Aug 9, 2012 | 10:31 AM
wrxmo's Avatar
Can't be the cat because normal its straight piped and it's a rough idle and I'm pretty sure there's a leak
Old Aug 11, 2012 | 03:11 PM
strider327's Avatar
Car Info: 2005 WRX
Does it just stay at 4k or does the rpm waver? Can you post a video?
Old Aug 11, 2012 | 06:07 PM
wrxmo's Avatar
Yeah I'll post one
Old Aug 13, 2012 | 10:18 AM
wrxmo's Avatar
The car stoped that power thing and now it has 7 codes all for cylinder 1 and 3 miss fire and mass air flow and exaust temp sensers
mmboost
Jan 9, 2004 11:25 PM
03wrbwrx
Apr 20, 2003 07:39 PM
subypd
Feb 23, 2003 03:46 PM
MidRex
Feb 12, 2003 06:23 AM
