list on which parts to get 1st to last?
Old May 12, 2004 | 08:54 PM
  #46
hezlok's Avatar
Car Info: basically stock wrx
Originally Posted by qwiktripn
Hummm... I have some concerns about some of the comments made on this post. First - Yes! the Cobb Access Port will make a signifigent difference. ECU managment is typically the most bang for the buck you will get; Cobb maps are safe, reliable, good power. Next, there's not... if any power/ reliablity given with air intakes or BOV (research this). Turboback exhausts are a very good first or second add-on. I would choose Prodrive or Borla hush for the catback - both are good and quiet, Greedy evo is quite too - but looks ricey.
Finally will such add-ons keep you up with Evo, I would say yes: check out Cobbs stats with the Cobb Stage 2 with T/back exhaust:
285 WHP
0-60 mph : 4.6 seconds
1/4 mile : 13.4 @ 101.5 mph
(Don't think a stock Evo will touch those numbers!)
yeah thats why i asked if it would keep up with the evo... another question, power packages for example the cobb stage 2 is the accessport and TBE, if i get a different kind of TBE like the superstealth turbo back mated with an axle back exhaust, will i get the same results as the real cobb stage 2?
Old May 12, 2004 | 11:07 PM
  #47
psychobooe's Avatar
That all depends on the DP that you get. I have the Helix one and it uses a bellmouth design very similar to the Cobb one. I'd say that any well-made bellmouth DP should give you the same hp.
qwiktripn - It's actually 285 flywheel hp. If you look at the Stage 2 dyno chart, the awhp is actually 224.5. Sorry.
Old May 13, 2004 | 04:47 PM
  #48
hezlok's Avatar
at least its 4.6 seconds ;D
Scoobywax
Jan 21, 2014 07:14 PM
dr3d1zzl3
Nov 13, 2003 11:36 AM
bambams247
Wanted
Jun 7, 2003 05:35 PM
Enigma76
May 8, 2003 03:46 PM
