Parallel Fuel Rail Mod
Old May 9, 2004 | 11:37 AM
Mister 2's Avatar
I got myself an extra stock fuel rail which I'm gonna convert to parallel feed. Anyone do this yet on a EJ20? (Yes, I've seen the other writeups). I've modded other fuel rails before but I'm just concerned about clearances at the end of the rail to determine which type of fittings I need. I'm also going with an aftermarket FPR that has dual inlets (one for each side). I'm thinking of mounting it on the firewall somewhere.
Any tips or suggestions appreciated. I'll be posting up pictures as it progresses. Also if anyone has a photo of the fuel rail area w/ the green brackets removed please share.
Thanks,
Dean
Old May 13, 2004 | 02:08 PM
WRXed's Avatar
Car Info: cars
When you get going on this, LMK. If you need any help, give me a call.
Ty
Old May 13, 2004 | 03:10 PM
Mister 2's Avatar
Thanks Ty, I'll let you know. Right now work is kickin' my *** (2pm - 2am).
Anyway I'm probably going to replace everything from the fuel filter. Check out this link for some interesting ideas:
http://www.stevetek.com/R-FuelSys.html
I want to see if the stock WRX fuel pump can keep up with STi injectors.
Old May 13, 2004 | 05:31 PM
WRXed's Avatar
Car Info: cars
No wonder I haven't seen you around. I'm in the same boat. Been working 7 days a week for the past couple of weeks.
Old May 13, 2004 | 10:59 PM
Mister 2's Avatar
Originally Posted by Concillian
That would be a negative. There's a reason that every vendor that sells a package including the STi injectors also includes a fuel pump. You'll start losing pressure not long after you start exceeding the limitations of the stock injectors.
The stock fuel pump has a little extra room over the stock injectors, but not much.
Did you read the link above? Granted the stock pump may not flow much but removing flow restrictions will free up a lot. In any case I do have a fuel pressure gauge and will be closely monitoring fuel pressure. If I recall from a post somewhere, converting to a parallel fuel rail increased fuel pressure about 7 psi (this is still using the stock regulator).
unth3
Hawaii Classifieds
Aug 11, 2010 04:56 PM
Mister 2
14
Dec 14, 2004 11:50 AM
CurlyPete
24
Aug 30, 2003 12:08 PM
zigenroller
Apr 18, 2003 04:33 AM
Daios
Dec 4, 2002 10:21 AM
