Injen or similar CAI - does it increase power? (was: need help all u pros)
Old Jan 16, 2006 | 12:02 PM
  #46
Originally Posted by Donkey
That would be a cool idea!Just gotta watch out for the puddles though!I've seen a kit out there that does use the foglight as a ram air inlet.Can't remeber where i saw it though.Alot of people don't realize that if you remove the snorkus you must remove the gasket from the air box as well.By removing the gasket the opening goes from a 2 3/4" to 3 1/2".
i live in so cal so i wont have to worry as much as you
you can pull the safari ralley intake system hehe
Old Jan 16, 2006 | 02:06 PM
  #47
Donkey's Avatar
Car Info: 02' WRX
Originally Posted by FujiApples
heh alright.. doesnt the ecu also base the fuel ratio on the manifold pressure?
It uses the MAF for fuel and the MAP(manifold absolute pressure) sensor to reference boost pressure for controling the EBC solenoid.
Old Jan 16, 2006 | 04:29 PM
  #48
air fuel ratio sensor as well
Old Jan 23, 2006 | 01:48 AM
  #49
dizmfker's Avatar
dumb question. i am reading that intake + water is not a good thing. but i see people all over run crazy setups with TMICs or FMIC and their CF Hoods w/ Vents where water can enter.. how is this possible?
Old Jan 23, 2006 | 10:07 AM
  #50
Donkey's Avatar
Car Info: 02' WRX
The water is only a problem (hydrolock) when a good volume is injested at once.For example:You install a cold air intake that places the filter too far down towars the bottom of the fender skirt.It rains heavily.You hit big puddle and suck up water.AEM has actually made a intake bypass coupling valve that can prevent this from happening.
accordr33
Aug 18, 2008 09:25 AM
moffman42
Sep 25, 2006 07:28 AM
stealth_wagon
Dec 6, 2005 03:59 PM
02silversuby
Nov 27, 2003 10:49 PM
