how to increase low end power?
Old Nov 25, 2003 | 06:03 PM
SuboobaruWRSEX's Avatar
Car Info: Viper ACR & H1
An up pipe, lightning the rotational mass will get the engine spinin quicker. Look at parts that give you the most torque. Torque is from 0 to movin, so somthing that gives you more torque is what your lookin for.
Nick
Old Nov 25, 2003 | 07:21 PM
Wingless Wonder's Avatar
Lighter weight wheel/tire combination will help in that area, too. Each one acts as a flywheel and the heavier it is, the more it resists acceleration.
We have what amounts to a low-compression engine that is probably outperformed by the 2.5 RS until boost starts to come on.
Things like intercooler hoses and underdrive pulleys might give a very slight increase. A turbo back exhaust should be noticeable. For reasonable money Deadbolt will polish your stock TD04 to improve the onset of boost and slightly improve overall efficiency, according to them.
Old Nov 25, 2003 | 09:02 PM
If any car needs Subaru's AVCS, it's the WRX.
Old Nov 26, 2003 | 09:08 AM
qwk_wrx's Avatar
Car Info: 05' Evo 8
remember we only have 2.0's so its kinda hard to build up low end power, an up-pipe will help faster spool up though and allow boost to come sooner...
Old Nov 27, 2003 | 12:05 PM
FiDRcr's Avatar
If you take a look at GFB's website, you'll find that their boost controller tremendously helped out the lower rpm range of the power band. This is because of the boost the car receives at a way earlier time. GFB....look under boost controller
~luke
Old Nov 27, 2003 | 10:36 PM
Even an MBC can give much improved boost at lower RPM. Just keep an eye on the boost gauge for the the part-throttle/full boost condition. This can occur with both an EBC and an MBC. I don't think this will happen in every driving situation, just at certain times. If I had to guess, it would be climbing grades at part-throttle. If the throttle position sensor doesn't see at least a certain percentage of throttle opening, it'll not go to full (stock) enrichment leading to a lean condition. The now-defunct Boost Monkey and the Vishnu EMI Adapter took care of that situation but these are now 'old' ways of engine management.
nic3krnnamja83
Mar 11, 2009 06:30 PM
FujiApples
49
Jan 23, 2006 10:07 AM
stealth_wagon
Dec 6, 2005 03:59 PM
Jonnyboy593
Jul 8, 2004 10:41 PM
Mach5WRX
21
Aug 22, 2003 12:51 PM
