Injen or similar CAI - does it increase power? (was: need help all u pros)
Originally Posted by sigma pi
whats wrong with that post?
Originally Posted by FujiApples
so i still dont get it.. the injen cai claims to be perfectly tuned for the ecu.. just like the typhoon, aps, and all the others.. so do i lose power? stay the same?
Car Info: .
an CAI or BOV will not cause lag.
A BOV to 100%atmosphere is just wasted air
Originally Posted by Donkey
You should not be giving anybody any advice.
+1 on a great thread!
daisuki vs donkey
hahahhaha
A 100% VTA BOV can cause lag and so can some CAI because of piping/intake tract lenght.Thats why short rams show better throttle responce than C.A.I.It's not just "wasted air". Its air that has been metered from the MAF sensor and needs to be accounted for.
either way i say dont get it
Originally Posted by kenji815
how about save your self the money remove the snorkel and get the same performance and sound out of it.
Done and Done.
Done and Done.
you have to take the silencer out from behind the quarter pannel
good job though eddie
heh alright.. doesnt the ecu also base the fuel ratio on the manifold pressure?
the awnser has been awnsered in the correct forum before please do a search
yes that and TPS also
but the stock box is connected to the intake silencer. that runs down and is narrow. i know the seal isnot perfectly air tight between the two, but its an ok seal. so if the length of the CAI isnt an issue. its also bigger in diameter.
looks sweet
the only reason i would run a short ram is because of a FMIC
i think there would be too much turbulance by the maf
its cheaper
and you khow it works
with that said i would get the mesh fogs for the 03 put the velocity stack where the fog light goes and put ram air in the stock box
that would be sweet to have
not sure it would make it faster but cool factor is there
its cheaper
looks sweet
its cheaper
its cheaper
