idle problems after DP and exhaust install
Old Jul 15, 2006 | 09:57 PM
Jakes02's Avatar
Car Info: 2002 WRX
Unhappy idle problems after DP and exhaust install
the car idled fine before i started. the only mods i have are the downpipe(non
catted) and the exhaust. initially the car idles and drives fine. as soon as the
radiator fans come on the engine starts studdering. the tachometer does not show this but you can hear that its about to stall and has stalled 2 out of the ten
times that the fans have come on. the boost gauge starts to jump when the idle gets rough. really confused. before i re-installed i made sure that the o2 sensor
was clean. i did remove the whole airbox for ease of access and re-installed when i was done. hhmmmm. so i'm wondering if its disconnecting the airflow sensor or the o2 sensor. or maybe i am
totally wrong. any ideas would be very appreciated. i also disconnected the battery hoping an ecu reset would do the trick
Old Jul 16, 2006 | 11:41 AM
Jakes02's Avatar
Car Info: 2002 WRX
Talking Problem Solved
in the threads about idling problems i never saw in anyones list of mods the snorkel delete. i noticed that when idling and the fans kicked on it would almost die BUT if i raised the hood it would idle fine with the fans on. i took off the snorkel and latched the hood. when the fans kicked on it idled perfect. i hope this will help someone in the future.
Old Jul 16, 2006 | 04:22 PM
Wingless Wonder's Avatar
I read your posts about the rough idle but am confused about whether you tried to run the engine with the complete airbox removed and MAF sensor disconnected.
The MAF sensor is critical to proper running of the engine. This is why installing aftermarket intakes can affect the power output, sometimes for better, sometimes worse. The sensor is very sensitive to even minute changes in airflow.
When in doubt, just use the airbox the way it came from the factory because with your exhaust mods, the intake path is still not a restriction until the mods are such that the engine requires more air. Subaru spent a lot of time and money to develop an intake system that is well-matched to its engines. It's much more involved than just bolting on a piece of tubing because the ECU is carefully mapped using input from various sensors on the engine.
Old Jul 16, 2006 | 10:43 PM
Jakes02's Avatar
Car Info: 2002 WRX
no the stock airbox was installed when i ran the engine. i do not have an aftermarket intake.
i<3dirt
Oct 20, 2014 10:26 AM
GnarBQ
Aug 26, 2014 10:21 PM
rallied out wrx
May 28, 2006 01:54 PM
grex767
May 27, 2006 10:37 AM
WRXcape
Jul 21, 2004 05:53 PM
