Rough idle (after catback and boost gauge install)
Old Jul 19, 2004 | 11:02 AM
RoadSpike's Avatar
Originally Posted by WRXcape
My car was stock for a little while until a couple of days ago I put on an Perrin cat-back. I also threw in an oil-pressure and boost gauge [the boost gauge is not completely hooked up yet (p.s. if you give the guys helping you to much beer they get drunk and rowdy and don't finish working on your car)].
Anyway now at idle my car sounds like an old man on crack. It sits at about 1000 rpm then will drop to around 300-400 almost sputtering out. It sounds like it is idiling a lot harder than it ever did before.
I asked a friend of mine and he said that his Firebird used to do the same. Thats all well and good but my car is a 2004 not a 1983. Is this anything to worry about? And if so how do i fix it?
Thanks in advance
If you tapped the vacuum line for the boost gauge and its leaking it would cause that.
Old Jul 19, 2004 | 01:26 PM
RoadSpike's Avatar
just get a can of wd-40 and spray on the vacuum line
if the idle suddenly jumps up a bit it would mean you have a leak there.
Old Jul 20, 2004 | 12:08 PM
Mulder's Avatar
Car Info: 02 WRX WRB
If by "not completely hooked up yet" you mean that the hose was connected at the engine but not connected to the gauge, then this is your problem. The open line from the manifold is causing a vacuum leak. If you aren't going to finish the gauge install immediately, either remove the tap and put the line back the way it was, or plug the end of the hose with a tight-fitting screw so it doesn't leak any more. Once you take care of this your car should run normally.
Old Jul 20, 2004 | 06:12 PM
oct1285's Avatar
Car Info: iono nemore
not to hijack the thread, but i kinda have a similiar issue with my boost gauge. I dont notice any differences in idle, but the needle in my boost gauge kinda shakes at idle but then it smoothly climbs as i drive. Sometimes its smooth, sometimes it shakes like crazy at idle.
Old Jul 21, 2004 | 10:39 AM
RoadSpike's Avatar
Where did you tap into.
I believe the boost gauge stock is setup to be connected into the blowoff valve vacuume line.
Old Jul 21, 2004 | 10:59 AM
oct1285's Avatar
i tapped into the stock bov line. The thing works and reads boost, but i kinda want it to work perfectly.
Old Jul 21, 2004 | 11:02 AM
RoadSpike's Avatar
I suppose it could be a small leak in the line but i've never really looked at the boost gauge at idle. I guess you'll need a second opinion
Old Jul 21, 2004 | 12:02 PM
RussB's Avatar
Car Info: $200,000 sports car
it probably is working right. idle isn't always at a constant rpm just because your tachometer says it is, the signal is filtered for that. vaccuum isn't constant either, but most gauges don't have much filtering or dampening. sometimes mine wavers a little at idle, other times it's rock solid.
Old Jul 21, 2004 | 05:53 PM
Choku Dori's Avatar
Car Info: Corvette Z51
This might not remedy the problem necessarily, but remember to reset your ECU whenever you slap on a new mod. It could help, but then again the problem might be bigger than just that. Good luck.
i<3dirt
Oct 20, 2014 10:26 AM
GnarBQ
Aug 26, 2014 10:21 PM
dthack03
Apr 23, 2014 08:02 AM
rallied out wrx
May 28, 2006 01:54 PM
fixmuflym
Dec 13, 2004 06:36 PM
