How hard is it to install a resistor on the uppipe 02?
Old Jan 27, 2003 | 07:11 PM
big sky's Avatar
Car Info: 04 GGA+
The resistor is no problem. When you remove your old uppipe you simply disconnect the egt probe lead (the rest remains on your old uppipe), your know left w/ a harness receptacle w/ two female slots- just take the resistor and fold the ends over and stick them in the harness receptacle- like pluggin in a two prong plug into a outlet! Tape over w/ electricians tape. That's it, the ecu will know see a constant temp-telling it everything is A OK.
The uppipe itself is a little more difficult. It is a very worthwhile mod- a must do in my book for lots of reasons- lowers egts=good, lowers spool=good, no chance of the cat disentagrating into your turbo=good, 7-10hp/ft lbs torque= good.
Big Sky
Old Jan 27, 2003 | 07:39 PM
capt'n'caveman's Avatar
Car Info: platinum rex wagon
the connector is very accessible....so even if you don't put in the resistor during the up-pipe instal....you can do it down the road if you start getting a cel
Old Sep 30, 2003 | 10:10 PM
GottaREX's Avatar
Car Info: 02 WRX
Big Sky
What exactly is this resistor mod? I'm gutting my uppipe tomorrow and hope I can also do this so I won't get any problems. thanks
Old Sep 30, 2003 | 11:28 PM
mmboost's Avatar
It fakes out the ECU into believing it is getting a valid signal from the EGT sensor indicating the catalytic convertor is OK.
Like big sky said, you put the 2.2k resistor across the leads, tape it up and you're set. I have a Perrin uppipe and this is exactly what I did. Never had a CEL since or any problems. The ECU actually doesn't tune any performance/safety parameters based upon readings from the uppipe's EGT sensor, so you're not affecting anythign important by doing this fix.
jason
anthonymx
Sep 24, 2011 01:58 PM
iyamada
Oct 17, 2006 02:52 PM
dunnojack
Jul 19, 2005 02:15 PM
Zoeb2s
Jun 3, 2003 11:46 PM
WRX_AUSTRIA
Dec 9, 2002 03:56 AM
