keep blowing fuse SBF#5 - is it the uppipe resistor? (was: Need Help!!!)
Old Oct 8, 2006 | 11:44 PM
iyamada's Avatar
Car Info: 2005 WRX WAGON
Need Help!!!
I just installed my perrin up and downpipes, but I keep blowing fuse SBF#5 (blew 4 already). I think it has something to do with the resistor for the uppipe. I have a cel fix for the downpipe so i don't think it's that. Don't really know if I installed the resistor correctly. I just put one end of the resistor into a hole in the EGT plug and the other end into the other hole. Could it be the EGT sensor? The way I installed it? The resistor? I have know idea what's going on and what i should do. Please help me out guys.
Old Oct 9, 2006 | 05:05 AM
Scoobtastic's Avatar
Car Info: Turbo 2000(UK) model CG8....300bhp,more to come!!:
check to make sure your loom is not on a heat source,hence the shorting and blowing of fuses,hope this helps...
Old Oct 15, 2006 | 10:09 AM
mattsn0w's Avatar
well, I am not sure what fuse SBF#5 is, but I can tell you that I do have the resister fix for my uppipe and a protune. All the resistor does is tell the ECU that the EGTs are at a constant 1275 degrees Fahrenheit. it should only connect to one side of the plug(that goes back to the ECU), not both male and female plugs(ECU and EGT sensor).
Since I don't know all of the symbols in a wiring schematic, I can't make a lot of sense from the Subaru wiring diagram.
Here is what is listed:
And here is what MB-9 connects to:
Old Oct 17, 2006 | 12:29 PM
iyamada's Avatar
actually fixed it last week. the problem was the downpipe cel fix was smashed to the underneath of my car. thanks for the advice tho
Old Oct 17, 2006 | 01:55 PM
wow mcdrama where did you get that?
Old Oct 17, 2006 | 01:58 PM
mattsn0w's Avatar
I have PDFs of all the manuals for 02-04 wrx/sti.
Old Oct 17, 2006 | 02:52 PM
w0w thats good stuff
PSBeachBum
May 31, 2012 06:55 PM
bluwrxwgn
May 23, 2009 03:50 PM
jjm3
Feb 7, 2009 05:01 PM
Novtec1
Jan 12, 2008 01:45 PM
wizurd
Jun 18, 2003 01:30 AM
