Engine Heat.......
Old Mar 24, 2004 | 11:58 AM
esracer's Avatar
Car Info: 2002 Honda S2000
Question Engine Heat.......
I installed my downpipe a few weeks ago and was wondering about the heat shield. I know that heat is one of the enemies of performance. Will leaving the heat shield off really hurt any performance of the car by lowering temperatures? So baiscally my question is......is a heat shield worth the money?
Old Mar 24, 2004 | 01:31 PM
Ditty77's Avatar
Car Info: 2002 WRX
Re: Engine Heat.......
what do you mean?
Old Mar 24, 2004 | 01:59 PM
ScoobyBoy's Avatar
yes the heat shield is worth the money.
you can just hack the stock shield to fit as well.
Old Mar 24, 2004 | 02:11 PM
esracer's Avatar
Re: Re: Engine Heat.......
Originally posted by Ditty77
what do you mean?
I meaning....does the decrease in engine heat by having a heat shield really make a difference in power? I took my heat shield off when I installed my exhaust system and was too lazy to put the heat shield back on.
Old Mar 24, 2004 | 03:01 PM
wrx10404's Avatar
Car Info: 04' wrx
The bigest reason there is a heatsheild there is because the cat gets really hot trying to block all of that goood exhaust. If you have no cat you have a lot less heat. If you have the cat you might want to put the heat sheild back on. The dp is still pretty hot but i have noticed that mine cools very quickly.
Old Mar 25, 2004 | 11:58 AM
esracer's Avatar
k thanks for the input
Old Mar 25, 2004 | 01:59 PM
DizzyWRX's Avatar
I bought a heat shield from www.speedmonkey.com to replace the stock one since i installed a turboback. Not sure how much better it is than the stocker, but it helps. I don't think that the performance difference due to the heat can be felt by the butt dyno.
Old Mar 26, 2004 | 09:02 AM
ride5000's Avatar
the heat shield is for the TURBO more than the dp.
hack the stocker and put it back on, or buy an aftermarket one.
either way, you really should put one back on. there's only about a foot between turbo and IC.
like the McDLT: "keep the hot side hot and the cool side cool."
jm2c
ken
moto96793
Hawaii Classifieds
Mar 15, 2015 07:38 PM
akdmx
Jan 26, 2009 09:32 AM
gtfaded
Mar 23, 2007 07:08 AM
Wingless Wonder
Jun 18, 2006 06:27 AM
rash
May 17, 2003 12:32 PM
