did some installs.. found some problems..
Old Jun 5, 2005 | 06:06 PM
  #31
norcalridin's Avatar
Car Info: 2002 WRB WRX
will do.. hopefully you guys can help me figure out what the *** is up with my car..
Old Jun 5, 2005 | 06:55 PM
  #32
Egan's Avatar
I'll bring my laptop so I can pull the cel code for you.
Old Jun 5, 2005 | 07:05 PM
  #33
wow that would be great.. thanx egan...
Old Jun 5, 2005 | 07:50 PM
  #34
http://forums.nasioc.com/forums/showthread.php?t=763346
just about the same problems as all these people on there.. but i hope its not a turbo problem like the last guy on the post...
Old Jun 8, 2005 | 12:48 PM
  #35
i did your mom's Avatar
Car Info: 05' WRX Sedan
dude, im almost 100% positive that it is just the new turbo noises. Cuz my car makes the same whirl whistle BUT only when i enter into boost. U could try tightening the wastegate arm bolt a 1/2 a turn and see if the noise persists. but i gaurentee u its just new sounds ur not used to. I keep steady boost throughout all my gears and i hear the whirl. its all good yooo. hopefully u get everything sorted out. keep us posted...lata mang
Old Jun 8, 2005 | 02:08 PM
  #36
Egan's Avatar
I ran several different uppipe/downpipe configurations along with the stock and aftermarket turbos on my WRX and never had a whistle. My STi now has a complete turboback exhaust as well. I definitely heard the turbo more, along with wastegate flutter, but until someone puts and ear to norcal's car I wouldn't make a guarantee one way or the other. The problem with diagnosing sounds over the internet is that we all interpret things differently. A whistle to one person could be a howl to another. We'll check him out in person and see what's up. Better safe than sorry.
Old Jun 9, 2005 | 01:01 PM
  #37
very true....good ****. hopefully everything gets fixed with ur car mang! good luck
Old Jun 9, 2005 | 09:01 PM
  #38
thanx man im hoping so.. im going to the meet on saturday to see whats going on with everyone, and to also see if some people can spread some knowledge on me about fixing this dam whistle...
Old Jun 10, 2005 | 11:51 AM
  #39
an update.. after many people have driven my car.. and after me and my dad spent about 2 hours looking around and driving it up and down the streets.. we have came to a conclusion that the reason the rpms are going up so fast is becuase my clutch is bad.. it is slipping like no other... a while back i noticed that starting off was harsher than when i first got the car, now you have to relase the clutch alot more when starting from a stop.. and also when i shift into gears, if i have it floored, it will stay at an rpm for about a second before it climbs in rpms.. when i would be rolling, in any gear 2-5.. and i floor it and keep it down.. the rpms would gradually increase, then it would increase about 2k rpm within a second and then go back down and then keep on increasing increasing normally... which the only thing we can truely belive it to be woud be a bad clutch... now as for the whisteling.. i still have no ***in idea whut exactly it is.. and hopefully at the saturday meet someone could help me find out!!
Old Jun 12, 2005 | 12:30 PM
  #40
itwrx's Avatar
Car Info: 03 WRX Blue
Usually the clutch smells really bad when its slipping. do you smell anything nasty?
Old Jun 12, 2005 | 08:45 PM
  #41
well it doesnt smell when im driving.. but then again what else could it be... it doesnt grab when i gas the car under 4k rpm... that is the onlyu time it will take the rpm up and then bring them back down as it accelerates as the rpms lower...
Old Jun 12, 2005 | 09:43 PM
  #42
Egan's Avatar
Here's the true test of a failing clutch:
1) Back car up to a speed bump or concrete block so it can't roll back.
2) Engage emergency brake
3) Let clutch in 1st and give gas
If the car stalls, the clutch is fine. If the engine keeps spinning, your clutch is shot.
Old Jun 12, 2005 | 09:56 PM
  #43
well if its not fully shot but gettin there (i guess thats right).... then wont that *** up the clutch even more...
Old Jun 12, 2005 | 10:34 PM
  #44
Egan's Avatar
If your clutch is shot, it needs to be replaced. 2 or 3 seconds of abuse won't make a difference one way or the other. This is no different than leaving the clutch in too long on an uphill start. A few times won't hurt the clutch. It's long term abuse that usually causes a clutch to go.
Old Jun 12, 2005 | 10:49 PM
  #45
i guess your right... but i mean what else could it be..
joltdudeuc
Oct 11, 2008 01:29 PM
-WickedRex-
Dec 18, 2006 06:57 PM
grex767
May 27, 2006 10:37 AM
suby_dude
Dec 12, 2005 03:33 PM
