did some installs.. found some problems..
Old Jun 2, 2005 | 04:47 AM
Egan's Avatar
Originally Posted by norcalridin
but anyways.. i now notice that when i drive to redline and shift, when it gets into the next gear with my foot floored.. it gives a hesitation before it picks up even thought its already in 4k rpm area.. so im guessing it can "only" be a leak??
The hesitation could be from your lack of engine management.
Old Jun 2, 2005 | 08:05 PM
norcalridin's Avatar
Car Info: 2002 WRB WRX
i could be, but when like i said when i shift into a gear comming from redline, it gets into a higher rpm really quick, then it dies down and catches back up.. and it does that everytime.. even when i am rolling and punch it, when it builds boost around 3500 rpm, it goes up to 4000rpm extremely fast then it goes back down to about 3500 again... i also noticed that when im just driving, when i put on the clutch and take my foot off the gas, it seems like the rpm stays up a little longer like it stays the same when i shift.. instead of dying rpms right as i take my foot off the peddle... maybe i should just meet somehwere with you sometime to show you what the *** is going on..
Originally Posted by i did your mom
im pretty sure its just the sound of the turbo spooling up. 1. do you hear an exhaust leak with the car at idle or just reving it a little bit?exhaust leaks r REAL noticeable and if not, then im almost 100% positive that it is just the new found turbo noises. If it was a leak, then over time, the gasket would get blown out more and more and the noise would be VERY noticeable at idle and low rev's. Just re-torque the bolts down and let it be.
i did your mom... at first i thought that was the noise, but now the sounds on all the time, its a contant whistle... ill admit thought it does sounds preaty slick driving it whitseling everywhere.. but it does get old...
i was thinking that maybe it could be a hose loose or something...
Old Jun 2, 2005 | 08:24 PM
Egan's Avatar
Argh, that sounds like the symptoms of a clutch going out. It could be something else though.
Let me know if you want to swing by sometime. You could also come by the weekly Saturday night meet in Natomas. 6PM at the corner of Del Paso and Natomas/Truxel. We're in the Border's lot, closer to the end where Pick Up Stix is.
Old Jun 4, 2005 | 01:05 AM
ok i put new gaskets in the top and bottom of the uppipe.. and it still is leaking somehwhere.. its almost like its a hose cracked or something... but it does sound like its comming str8 from the intercooler when inside the car...
Old Jun 4, 2005 | 06:06 AM
sonicrx's Avatar
Car Info: not stock
check your bov i have seen the come loose a little ,and i have seen gfb bovs base loosen up from the body and cause that same whistle. anyways it is a bov whistle i see it all the time.
Old Jun 4, 2005 | 03:42 PM
it does sound like it is, only becuase its so loud comming from that area, and when its relasing the excess air its really loud also... but where do i check... becuz the bolts are on tight and it seems to be on there...
Old Jun 5, 2005 | 06:48 AM
sonicrx's Avatar
Car Info: not stock
check the clamp that holds the hose on the bov. also unbolt it and check the gasket. to might have a hole in the hose somewhere also.
Old Jun 5, 2005 | 08:52 AM
Egan's Avatar
Did you take the inercooler off to do the downpipe install? I always leave mine on so I didn't even think about that. As sonic said, and if you did indeed remove the IC, the hose that clamps onto the turbo outlet is a common source of leak. The BOV gasket should be okay as I re-used mine several times, but it is worth checking also. Also check the vacuum line off the end of the BOV.
Do you have a boost gauge? Are you seeing lower than normal boost levels when the whistling is happening?
Old Jun 5, 2005 | 09:41 AM
the clamp that is on the turbo is on preaty tight, yues i have a boost guage and no my boost has stayed the same throughout this whole headaching journey..
Old Jun 5, 2005 | 09:52 AM
oh and an update, my check engine light came on last night when i was driving, but im preaty sure that it is for my downpipe....
Old Jun 5, 2005 | 10:03 AM
Egan's Avatar
I'm thinking your problem is before the turbo. If it was the hoses after the turbo or BOV, you should see a drop in boost. That brings us back to the uppipe or downpipe.
Old Jun 5, 2005 | 11:33 AM
which if it was the uppipe, i replaced both gaskets on the uppipe, but yet i didnt on the downpipe, but the downpipe had doubled gaskets when i took it off, the only thing i could think of would be a leak in the flex section of the uppipe, but it is brand new, could there be a leak in it that fast??
Old Jun 5, 2005 | 12:42 PM
Egan's Avatar
Come out to the meet on Saturday night and we should be able to pinpoint it. We have several mechanically inclined folks there including reps from Subaru Specialists. We'll get it figured out for you.
Old Jun 5, 2005 | 04:42 PM
man i wish i would have known that i would have come.. i was going to come out and see whuts going on yesterday night, but one i was buzy workign and i didnt think you guys would want me to bother you with my problems...
Old Jun 5, 2005 | 05:25 PM
Egan's Avatar
That's what we're here for. Come down next Saturday.
