did some installs.. found some problems..
Old May 30, 2005 | 07:27 PM
norcalridin's Avatar
Car Info: 2002 WRB WRX
over the weekend i installed a DC uppipe, and an HKS downpipe and i did the snorkaletemy... everything went okay in the install.. took me alone about 5 hours to do it all... not bad for a 17 year old.. anyways after i put everything back together.. i took the car around the block.. and immediatly when i would get into the 2000 rpm range and all the way up to redline there is this loud *** whistle and then when i would let off it sounds like i have an aftermarket BOV like its really loud.... i drove around all last night and it whistled everywhere i went in the 2-7k rpm range getting louder as higher rpms hit.. i also noticed that if im at around 2500 rpm and i stomp on it as soon as it hits a little higher i just notice a peak climb in the rpm.. like it really pauses then when it hits 3k rpm it just screams all the way too redline.. just an FYI.. i am using all of the stock gaskets on both the uppipe and downpipe.. but im wondering if there could be a leak somewhere and the loud whitling is comming from those.. i already am going to buy new gaskets and see if that helps.. but im wondering if this has happened to anyone else.. if the turbo is really supposed to be this loud.. but on top of it all.. my downpipe didnt throw a CEL... so thats an upside to it all.. but i already have a CEL fix for that sitting at my house so its there when i need it.. anyways any help at all would be great.. as i am sort of worrying and i need to know if what my car is doin is normal....
Old May 30, 2005 | 08:47 PM
pbchief2's Avatar
Car Info: 1995 Impreza L
Sounds like an uppipe leak. It's a pretty common problem inexperienced(and even experienced) people run into when installing the uppipe. It's also possible that the flanges are not a perfect fit and using 2 gaskets between the header and upipe might help that.
Last edited by pbchief2; May 30, 2005 at 09:13 PM. Reason: I swear there must be someone changing my spelling now ant then
Old May 30, 2005 | 09:05 PM
Originally Posted by pbchief2
Sounds like an uppipe leak. It's a pretty common problem inexperienced(and even experienced) people run into when installing the uppipe. It's also possible that the flages are not a perfect fit and ussing 2 gaskets between the header and upipe might help that.
so you think that it is a leak.. that there is no way it should be that loud.. becuz it sounds like straight whistle when i drive... so should i just buy a whole gasket kit from somewhere...
Old May 30, 2005 | 09:12 PM
pbchief2's Avatar
If it's a whistle its most likely the uppipe. You should only have to replace the the two uppipe gaskets and the downpipe to turbo gasket. If all else fails take it to subaru specialists.
Old May 30, 2005 | 10:03 PM
anybody else have this problem.... i want to just go to subaru and get the gasket cuz i kno they will have then in stock.. but i dont wanna pay 20 bux for it.. so im going to go to my buddies shop...
Old May 30, 2005 | 10:09 PM
Egan's Avatar
I concur with Ben - it sounds like a leak. It's most likely your uppipe. Did you torque all of the bolts to 26 ft-lbs? Did you use a brand new gasket? Are seeing any loss in boost?
Old May 30, 2005 | 10:10 PM
Egan's Avatar
I'll keep my ears out for you whistling through my neighborhood.
Old May 30, 2005 | 10:21 PM
haha you better.. hopefully i will get it fixed soon.. one of these days we will meet up somewhere.. i kno this..
i torqued all the bolts basically tighter than 26lbs.. cuz i just went till it was tuff to turn.. i didnt use new gaskets.. im gonna buy some soon from a local shop...
Old May 30, 2005 | 10:29 PM
Egan's Avatar
The used gasket part is most likely the source of your leak. The uppipe-turbo and downpipe-turbo gaskets are the most essential to replace when you mess with either of those exhaust pieces. Don't over torque the bolts or you may have a problem getting them off later. They tend to tighten with all of that heat.
We have a weekly Subaru meet in the Natomas area every Saturday night. You should come by sometime. https://www.i-club.com/forums/meetings-events-group-streaking-118/weekly-sacramento-saturday-meets-6pm-every-saturday-30788/
Old Jun 1, 2005 | 04:43 PM
well i installed new gaskets for the uppipe that i bought from suabaru for 45 bux.. anyways.. it didnt stop the whistle.. its still the same but the weird thing that i noticed was that it only makes the whistle when the car is in gear.. when you rev it just sitting still.. it just sounds normal.. but when you drive it and go to redline it is a whistle maniac.. PLZ HELP
Old Jun 1, 2005 | 05:06 PM
pbchief2's Avatar
Its definitely a leak, the reason you dont hear a whistle when the car is'nt in gear is because there's no load.
Old Jun 1, 2005 | 06:24 PM
Egan's Avatar
Do you have a bung for the EGT sensor? It's possible the threads are loose.
Old Jun 1, 2005 | 06:27 PM
well its weird though because when i replaced the gasket that had a crack in it.. it still does it.. like it whistles then when i let off, it sounds like an aftermarket BOV... maybe i should just try replacing every single gasket..
yeah i do have a bung and i put it in there preaty tight.. i could check that...
but anyways.. i now notice that when i drive to redline and shift, when it gets into the next gear with my foot floored.. it gives a hesitation before it picks up even thought its already in 4k rpm area.. so im guessing it can "only" be a leak??
Old Jun 1, 2005 | 08:45 PM
hulksmash's Avatar
it's normal. don't worry about it. an exhaust leak does not make a whistle.
Old Jun 1, 2005 | 11:36 PM
i did your mom's Avatar
Car Info: 05' WRX Sedan
im pretty sure its just the sound of the turbo spooling up. 1. do you hear an exhaust leak with the car at idle or just reving it a little bit?exhaust leaks r REAL noticeable and if not, then im almost 100% positive that it is just the new found turbo noises. If it was a leak, then over time, the gasket would get blown out more and more and the noise would be VERY noticeable at idle and low rev's. Just re-torque the bolts down and let it be.
