Crazy boost spiking and jumping!!
Old Jun 4, 2006 | 03:23 AM
rustokman's Avatar
Car Info: Black 03 WRX
So I am driving my car today and I notoce that it's jerking kind of bad. So I monitor the turbo guage for a little while and I notice that the boost is jumping from 15 down o 10 and back up to 15.. It's doing this very fast and the car is reacting to it. I tried resetting the ecu but that didn't help. I have a feeling it's a vacuum line but I have my doubts for various reasons.
I have a few mods in the car including an STi uppipe, removed silencer, kn filter, and an aftermarket turbo guage.
Does anyone have any ideas as to what it may be?
Thanks in advance
Rus
Old Jun 5, 2006 | 12:23 AM
rustokman's Avatar
anyone??
So here's some more info.. When the engine is a bit cooler, like when I get in after not driving for a little while, the turbo is laggy and won't climb past like 10 psi. Then when it heats up it starts going crazy. Also, if I let the turbo climb gradually, it doesn't spike crazy.. it kind of balances out. When I stomp on the gas, the turbo climbs super quick and then once past 10 psi starts going crazy. Also, the idle pressure is lower than usual, it is at about -25 psi. It used to be at like -20 psi.
Maybe I have a boost leak somewhere? Or is it vaccum lines? Or is it someting wrong with the wastegate? Those are the only things I can think of.
Old Jun 14, 2006 | 02:45 PM
rustokman's Avatar
so no one knows? no one has any ideas?
Old Jun 14, 2006 | 05:27 PM
Cody8675309's Avatar
Check for boost/vacuum line leaks. If you have a buddy with the same car, try swapping boost solenoids. Maybe your's is borked.
Old Jun 15, 2006 | 02:26 PM
BIG GUN's Avatar
Car Info: 2002 WRX SILVER WAGON
Spiking
I have a similar problem w/ my 02 wagon that was protuned by TDC. Jon told me that it was the ECU trying to make target, overshooting, the correcting. He said it was a simple cure. Jerry, at Deadbolt suggested that the pill i.d. might need to be a little larger. I have one of the infamous Momentum 40T's, and it has been suggested that the hot side need's to be ported.
This only happens during accelleration at slightly less than WFO!
Old Jun 15, 2006 | 04:41 PM
subywrx's Avatar
What other mods do you have except up-pipe?
Old Jun 18, 2006 | 08:27 PM
rustokman's Avatar
well, I have a boost guage and an axle back. I checked the link at the boost guage and it seems fine. I also have a k&n, and i cut out the silencer. I have a few suspension mods (that are making my right side click all the time).
Old Jun 24, 2006 | 03:14 PM
rustokman's Avatar
it kind of went away now but it seems like the vacuum is way to low now at idle... it's reading at like -25 when I am cruising and not pushing any gas... I'm not sure but I thikn it used to be somewhere around -20.
chimchimm5
Jan 6, 2009 03:32 PM
scoobiesleeper2
Mar 30, 2006 12:49 PM
polyol
Dec 30, 2004 06:16 PM
WRXWagon203
Jul 14, 2004 02:10 PM
StlWrx
Dec 8, 2002 12:41 PM
