Coolant Leak
Old Jan 23, 2005 | 02:23 PM
WindingRoad's Avatar
Car Info: 2004 White GDB
Coolant Leak
I recently did a oil change and found out that I have a coolant leak somewhere. My whole transmission is tinted green and its sticky all around the lower part of my engine. Does anyone else have this problem? Where would the leak most likely be? Thanks for the responses.
Old Jan 23, 2005 | 03:28 PM
nic3krnnamja83's Avatar
i had a radiator problem back in june where i have white and greenish residue everywhere, and they did a presure check and it was too low so they replaced it. my guess it was leaking from a seams from the top. that was my experience sorry if that didnt help much
Old Jan 23, 2005 | 07:41 PM
kellie's Avatar
Car Info: 2002 WRX wagon x2
Perhaps the heater lines? I tried to find a picture of them, and failed, but they lead into the firewall. I say that because you mentioned that it was on the tranny, so it sounds like it's coming from somewhere in the back of the engine.
Old Jan 23, 2005 | 09:03 PM
I was thinking about that. I've tried to find where the coolant was leaking from but every line that i checked came out clean.
Old Feb 1, 2005 | 11:21 AM
fastnoypi's Avatar
double check the coolent lines from your turbo and also the coolant header tank, sometimes the clamps dont do their thing and have seen some instances where the hoses get brittle. It might be up in this area if you are getting coolant on top of your tranny.
Also, the coolant lines passing though your throttle body may be another area to check
Old Feb 1, 2005 | 11:26 AM
-j-'s Avatar
-j-
Car Info: 2006 Audi A3/2007 Civic Si
I had coolant leaks before too. The hoses on the radiator were all loose! Hope it's that easy.
snaggleto0th
Sep 12, 2010 09:54 PM
WindCloud
Aug 5, 2004 01:08 AM
overdose
Mar 17, 2004 11:56 AM
Peaty
Jan 29, 2004 01:08 AM
hokusai
Dec 29, 2003 06:23 PM
