VF34 Turbo?
Old Nov 4, 2004 | 10:14 AM
RussA's Avatar
Car Info: Aspin '02 WRX sedan
if you are getting a bigger turbo.... GET BIGGER INJECTORS AND FUEL PUMP. you engine will not be supplied with enough fuel if you get the bigger turbo without getting injectors and a pump with it....
the stock intercooler should work just fine. I am in debate whether to go with front mount or bigger top mount. Although the FMIC is so sick and what I've wanted... I think I just may go with a bigger top mount. You'll get a little more lag with the FMIC only because the air has got a longer distance to travel, but the reason I may stick with the TMIC is so that my car will not stand out. Cops are attracted to the shiney. I don't want to give them any visual reason to pull me over. And if they pop my hood, I want my engine to look as stock as possible...
Old Nov 12, 2004 | 10:11 PM
snicklous's Avatar
Car Info: '03 Wrx w/vf-34, sti pinks,tbe, 2.5l cobb block
i agree. you will need some type of engine management, sti pinks and a tbe to say the least.
