Coolant leak?
Old Dec 29, 2003 | 01:00 PM
hokusai's Avatar
Car Info: a Ford
Coolant leak?
It seems as if i have a coolant leak near the throttle body because there is dried coolant around the throttle body and some on the bov. Any ideas where it could be coming from? I will post a pic later when i have a chance.
Old Dec 29, 2003 | 02:47 PM
Slack's Avatar
Car Info: '02
Re: Coolant leak?
Well since you say it's by the TB check the coolant hose that goes into the TB.
Old Dec 29, 2003 | 03:01 PM
hokusai's Avatar
Car Info: a Ford
Will check, but it seemed fine from looking at it from the top.
Old Dec 29, 2003 | 03:12 PM
WindingRoad's Avatar
Car Info: 2004 White GDB
ed, i had a coolant leak somewhere on my truck and couldnt find the hole. i just had someone rev the motor and little squirts of coolant was coming out of one of my hoses. the hose may look fine but it leaks under pressure.
Old Dec 29, 2003 | 06:23 PM
hokusai's Avatar
Car Info: a Ford
ok, i found the problem. there was a small pin sized hole on the coolant line that hooks up to the throttle body. thanks for all the help.
snaggleto0th
Sep 12, 2010 09:54 PM
WindCloud
Aug 5, 2004 01:08 AM
Egan
16
Mar 18, 2004 07:45 AM
overdose
Mar 17, 2004 11:56 AM
Peaty
Jan 29, 2004 01:08 AM
