Check Engine light came on...
Old Jun 26, 2004 | 09:52 AM
Meeocky's Avatar
Unhappy Check Engine light came on...
I have a stock 2004 WRX and last night the Check Engine light came on when I started my car. I checked under the hood and I see nothing wrong, or any fluids low. The service departments at the few Subaru dealerships in Louisiana are closed on the weekend. I'm afraid of driving it this weekend and messing something up, but it drives fine. Any idea what could it be? Thanks.
Old Jun 26, 2004 | 09:56 AM
MO REX's Avatar
Car Info: 02 PSM WRX
If it happend after refueling you may have not put the gas cap on tight enough. If that is the case it should go off after awhile.
Old Jun 26, 2004 | 10:16 AM
Meeocky's Avatar
ok, nevermind. I think I have bad gas in the tank because yesterday when I was passing someone up, it kinda sputterd. I'm thinking something just detonated the light. So I disconnected the battery for like 3 minutes and reconnected it and the light went off. WHEW! I thought something was wrong for a second.
Old Jun 26, 2004 | 11:23 AM
Wrxneffect's Avatar
Car Info: 03 Wrx black sedan + 2013 BRZ
you could also try going to an Auto Zone, don't know if they have those out in Louisianna, and get the code pulled so you know why the CEL came on.
Jason
Old Jun 26, 2004 | 12:03 PM
RussB's Avatar
Car Info: $200,000 sports car
something IS wrong, that's why the light came on. bad gas can do bad things to your car. get the code checked and figure out what the problem is. odds are, it will come back on soon if you don't.
Old Jun 26, 2004 | 04:35 PM
MO REX's Avatar
Im not saying what you said is wrong, but could you please explain how you know something is wrong. My cel came on after I filled it with fuel and after a little driveing it went out and has been off for over 25k. If the sputter is the reason you think something is wrong, couldnt it be the ecu going into limp mode because of the cel. Like I said Im not saying your wrong (Im sure your right) I would just like to understand since I dont know much about how the ecu works.
Thanks.
Old Jun 26, 2004 | 06:03 PM
Mulder's Avatar
Car Info: 02 WRX WRB
There are over a hundred different things that can set trouble codes and turn on the CEL. All you know when the light goes on is that one of them has been detected. There is no way to determine for certain what the cause is other than doing a scan and reading the code. Even if you think you know what it is (loose gas cap etc) it is always best to get the code read to be sure. Doing a reset by disconnecting the battery is not a good idea, all this does is erase the code without correcting the problem. Chances are that unless it was a transitory condition such as the gas cap, the light will come back on anyway.
Old Jun 26, 2004 | 06:47 PM
BrianH's Avatar
Car Info: NONE
post in your reginal forum over on nasioc and see if someone local can come and pull the code for you with an obd2 scanner.
Old Jun 26, 2004 | 10:41 PM
RussB's Avatar
Thanks.
i hear what you're saying. i have no idea that something bad is wrong, or even anything at all is wrong. what i'm saying is that the computer thinks something is wrong, and it should get checked out. turning off lights is just a bandaid, it needs to be diagnosed and fixed so it won't come back.
Old Jun 27, 2004 | 02:10 PM
Littleboyblue's Avatar
Whether something is wrong or not, it cant hurt to have it looked at. Its under warranty!
Old Jun 27, 2004 | 03:30 PM
namakemono's Avatar
Car Info: gc w/ neons and a wrx that needs neons
if you are completely stock then it definately won't hurt to get it checked out by the dealership when you can.
i had my CEL come on after filling up a gas station, and thought it was just the gas cap. When i took my car in, i found out that there was a fracture in my spark plug. It came on again later that week and i had to get my ECU replaced. My car is probably the only one in a million, but sh*t happens.
Old Jul 2, 2004 | 10:21 AM
Meeocky's Avatar
It's been a week since I reset the ECU and the light hasn't came back on since. I guess it was just a fluke. Some random thing made it go off that one time.
Old Jul 2, 2004 | 11:42 AM
RoadSpike's Avatar
If you had water in your gas you can either buy water remover, or even more cheaply a bottle of rubbing alcohol and pour a good portion of it into a full tank of gas.
aaron222
Apr 12, 2005 11:18 AM
1neWRX
Jul 6, 2004 11:39 PM
kayo
13
Dec 24, 2003 07:27 AM
ctdragon
Aug 31, 2003 09:48 AM
spankmeplz700
Jan 4, 2003 11:28 AM
