CEL code help? limp mode?
Old Sep 15, 2008 | 01:35 AM
blkdout04's Avatar
Car Info: 04 java black pearl sti/06 honda ruckus
my car has done this a few times now, heres what its doing, when i shift from a lower to higher gear at around 5 to 6k rpm it will shut everything down, cel comes one, wont shift past 3k, doesnt boost at all, and my access port shows no trouble codes?? but once it cools off it shifts fine but cel stays on, still no code, and once i cool off the second time cel is off and runns fine untill the next time? its done it like 4-5 times, any ideas?
i took it to gst and they said it has a vac/boost leak, could that be the cause? they also inquired that i should be running a fmic, car has roughly 320 to teh wheels, bigger turbo all required upgrades for it, exhaust, intake , big maf injectors ect.....
any ideas? could the boost leak be causeing it to do that? will a fmic fix the problem?
any help would be great thanks
Old Sep 16, 2008 | 08:58 PM
blkdout04's Avatar
bump
Old Sep 17, 2008 | 07:58 AM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
If GST said it has a vacuum/boost leak, did you repair it?
Old Sep 17, 2008 | 10:39 PM
blkdout04's Avatar
attempted, but the bolt hole on the ic that hold the bov is stripped out, it has about an eigth inch I threads to grab, so I used some gasket sealant to help hold it, and the problem came back, Fmic in near future like within 2 weeks
stigirl808
Dec 31, 2012 04:31 PM
blkdout04
Sep 16, 2008 08:59 PM
blkdout04
Sep 15, 2008 07:09 AM
bodyboarder050
Aug 8, 2007 06:05 PM
dose84
Dec 26, 2004 07:04 PM
Top
