coolant leak
Old Aug 21, 2008 | 12:06 PM
skyz_wrx's Avatar
Car Info: 2002 subaru wrx
coolant leak
I have a problem with a coolant leak on my 02. i can hear it and smell it but can't find the leak. its near the coolant reservoir and the turbo area. you can hear it drip onto the down pipe. can anyone give me some directions so i start trouble shooting? thanks for reading my thread.
Old Aug 21, 2008 | 12:47 PM
strider327's Avatar
Car Info: 2005 WRX
There should be two hoses right on top of the reservoir. Check there first. I had a similar problem and I had to buy new clamps to ensure they were tight.
Old Aug 21, 2008 | 12:48 PM
wrxisthebest's Avatar
u sure its not the A/c water line? the condensation from ur a/c is poured right out on top of ur dp
Old Aug 21, 2008 | 06:50 PM
skyz_wrx's Avatar
i haven't ran my a/c all summer because i have a leak somewhere but ill take a look at it. as for the two hoses on the reservior tank i haven't replace them yet. but i replaced the one on the buttom right. where is a good place to find the hoses if i need to replace them. thanks for help.
Old Aug 21, 2008 | 09:36 PM
meilers's Avatar
Your A/C has NOTHING to do with your coolant system. Do you mean that you also have a (whatever they call the Freon replacement) leak as well?
Old Aug 21, 2008 | 09:44 PM
well im just thinking water hitting the dp...
Old Aug 22, 2008 | 08:50 AM
skyz_wrx's Avatar
im not too familar with the turbo. but are there coolant lines running into the turbo or lines around it?
Old Sep 18, 2008 | 04:58 PM
VRT MBasile's Avatar
bump for a resolution. I'm smelling coolant slightly after driving semi-aggressive.
snaggleto0th
Sep 12, 2010 09:54 PM
WindCloud
Aug 5, 2004 01:08 AM
overdose
Mar 17, 2004 11:56 AM
Peaty
Jan 29, 2004 01:08 AM
hokusai
Dec 29, 2003 06:23 PM
