2.2 turbo
Old Jan 20, 2003 | 12:37 AM
teiva-boy's Avatar
Car Info: Boosted Geo Prizm
Although it would be quite rewarding to turbo your N/A motor. All the time and money you put into it could be better spent on just doing an engine swap. You'll be up and running much quicker then a home brew turbo setup.
Old Jan 22, 2003 | 12:45 AM
teiva-boy's Avatar
Well getting 22b parts is near impossible. Like you said only a few hundred were made.
What you should do is get an already turbo'd legacy engine. I know of one guy personally that had done this and even used some parts from a EJ20 engine like a PDE down pipe and uppipe. So I am pretty sure that the exhaust pieces will work. Although he had a problem getting a VF30 in there as the angle of the housings were off for his FMIC setup.
Finding a junked tubo'd legacy shouldnt be too hard since well it's old. Then you just have to see if the engine is still in good condition or needs a rebuild/overhaul.
JDMGC8
May 29, 2009 08:07 PM
fuzzycuffs
Feb 8, 2004 06:38 AM
singsing
May 24, 2003 03:19 AM
KurleeDaddeeWRX
Mar 4, 2003 06:44 PM
samurai
Jan 16, 2003 05:46 PM
