Turboxs top mount intercooler
Old Jan 27, 2003 | 07:32 PM
1quikrex's Avatar
From: Perrin Race DP Perrin Up-pipe Blitz Nur-spec CB Blitz LM intake TXS UTEC GFB BOV
It would be good to know which splitters can work in conjunction with the txs tmi.
Old Jan 28, 2003 | 02:22 AM
Wingless Wonder's Avatar
Originally posted by maxxpsi
you have to remove that, i had the same problems, phil from turboxs said it had to be removed.
its very simple to do
I don't get this mod at all. It seems that the intercooler needs to get cooler outside air to flow through the core to drop the charge temperature. Subaru put it there for a reason. I understand that the larger intercooler creates interference, but it seems like a new seal should be designed to mate up to it.
^ww^
Old Jan 28, 2003 | 09:57 AM
WRX-Hellfire's Avatar
^ww^
I dont understand either. I always thought air takes the path of least resistance. Which in this case would go around the IC not through it as effectively as with a shroud.
johndabrit
Apr 17, 2010 01:41 PM
accordbalance
Sep 18, 2008 07:38 PM
Lazyboy
Dec 8, 2006 08:06 AM
Antonio85
Jun 24, 2005 10:24 AM
Bean
Dec 16, 2002 02:48 PM
