EGT readings
Old Mar 9, 2004 | 05:20 PM
go go go's Avatar
Car Info: GF8 ver6
EGT readings
I am thinking about installing EGT to help setting up my ECU.
The question I have is, what's considered safe temperature and where is the point where it gets dangerous.
Also, can somebody post the EGT reading?
maybe Max. EGT reading or the reading when cruisng the freeway.
my set up is, JDM EJ20 ver6 motor, Apex-i PowerFC ECU. Running on 91 octane, PowerFC shows little bit of knocking on 2nd gear 5500rpm and up even running on only 5lb of boost.
Old Mar 9, 2004 | 05:39 PM
AWD_Dan's Avatar
Car Info: White 2000 2.5RS-Turbo
I'd run about 1400-1450F crusing on the freeway never to exceed 1600 for any longer than about 20 seconds (Laguna seca straight) Idle around 800-1000... then again I always kept it a touch on the rich side for safety. An awesome tuning tool, EVERYONE should use one!
-Dan
Old Mar 10, 2004 | 06:53 PM
go go go's Avatar
Car Info: GF8 ver6
thanks for the input
Old Mar 26, 2004 | 09:18 AM
ride5000's Avatar
Originally posted by DAMOTORSPORT
1600 F is too high. The maximum you should see on your gauge is 1500 F. Most of the gausges are up to 1600 and this also explains the 1600 max limit. Most engine builders recommend 1500 F. But this is measured before the turbocharger. Not at the dump pipe!
1500 is overly conservative.
the bone stock car when driven hard will exceed that at the exhaust ports. data from azscooby.
jm2c
ken
Old Mar 29, 2004 | 08:20 AM
stott's Avatar
Car Info: 2004 STi Yellow/Black
1600 is right on w/ what I have also heard and use as a warning light to slow down for a bit w/ my EGT. I am running just about the exact same numbers as AWD_DAN on the street and apparently at the track too.
http://www.stifiles.com
stott
Old Apr 14, 2004 | 02:33 PM
Normally your EGTs are lower under full throttle/ full engine load than they are under steady freeway cruising. EGTs are directly related to the combination of ignition advance and lean AF ratio. Under full load your advance is high but the car should be richer, while at light load it can run somewhat lean with less advance for better fuel economy. Like Dan said, ~1600 is safe.
Old Apr 16, 2004 | 09:30 AM
ride5000's Avatar
what cylinder are you calling #3?
everything i've read puts that at passenger's side rear.
this is not the typical blown piston... that would be #4, driver's side rear.
an egt probe anywhere further than 6" from the exhaust ports is useless, imo.
jm2c
ken
madrex
Jan 11, 2004 09:57 PM
CurlyPete
Sep 20, 2003 05:56 PM
spdkills
Jan 25, 2003 03:48 PM
flyingace
Jan 11, 2003 02:10 PM
