An Oil Cooler done properly! Affordable Injectors! Power Packages! Built Motors!
An affordable Oil Cooler done the right way!
Anyone can assemble an “oil cooler kit” for the Subaru Impreza WRX / STI, but key components such as a thermostat, line size, core selection, and mounting location are critical components that many individuals overlook.
While track-side tuning Brian Locke’s WRX US Touring Car, the WRX’s ability to sufficiently cool its oil when operating in extreme conditions became glaringly apparent. Even in cool weather with moderate cycling, the factory system seems stressed, resulting in dangerously high oil temperatures (this is probably why the Spec C’s come with an oil cooler from the factory). After testing various solutions, we finally selected a setup that is more than capable of dealing with the stress of road racing.
With the Gruppe-S Oil Cooler, the racing oil temperature was reduced a consistent 40 degrees F, even in 110 degree + temperatures of Arizona, as proven with our data logs. In short, this oil-cooler works and it has been track tested on a race winning vehicle.
Key Features:
*High quality European core (240mm x 120mm x 45mm), not some Taiwanese knock off core.
*Thermostat operated Oil Cooler to avoid cooling cold oil upon startup.
*Aerospace fittings / stainless steel lines, professionally assembled and tested to 1000psi.
*Light weight mounting brackets.
In the words of Brian Lock, “this oil cooler rocks. After installing this setup we never had a problem with oil temperature again. Even at PIR where it was 115 and it was so hot inside the car I thought my legs were on fire, it was golden. Brian Lock thinks that this oil cooler is the *****, Brian Lock thinks you should buy it.”
Introductory Special: - $499 Shipped!
Thanks,
Preston
Phone: (510) 783-5300
We Accept Paypal!
Paypal: sales@gruppe-s.com
When ordering w/ paypal, please include the following:
product name: XXXX
sales rep: Preston
Price including shipping: $XXXX
Shipping address.
Key Features:
Thanks,
Preston
We Accept Paypal!
product name: XXXX
sales rep: Preston
Shipping address.
Finally! Affordable injectors that work well for the WRX and STi!
Helix Power has finally brought affordable injectors to the market for your WRX and STi. As it stands, there are very few, if any, affordable and well working replacement injectors for your Subaru. You could try to save and go for Perrin modded injectors but do you really want a stock STi injector that has simply had larger holes punched in the nozzle? You could not skimp on injectors but do you really want to pay $600+ for PEs? On top of that, the PEs can be difficult to tune for because some of them have high latency periods.
Helix injectors are custom manufactured in Japan by a world-famous OEM injector manufacturer. Helix injectors are custom built and engineered specifically for each application. Injector on-time, spray pattern, and flow rate are all properly matched for maximum power and reliability. All Helix injectors are carefully flow tested to ensure identical flow rates. Unlike the competition which modifies OEM injectors to achieve different flow rates (which often results in uneven fuel flow between cylinders), Helix injectors are designed and built from the ground up specifically for the designated flow rates.
- Economical Price
- OE performance: factory spray patter and on-time retained.
- Easy to tune
Helix Power 660cc Injectors for WRX + Walbro 255L FP and setup kit -
$499 Shipped!
$469 Shipped for just the Injectors!
- Ideal for VF series and PE size turbos on WRXs
- 340WHP Capable
Helix Power 820 cc Injectors for WRX + Walbro 255L FP and setup kit -
$519 Shipped!
$479 Shipped for just the Injectors!
- Ideal for medium to large size turbos on WRX (18G-20G, Green, GT30R, etc.)
- 450 WHP Capable
Helix Power 860 cc Injectors for STi + Walbro 255L FP and setup kit -
$539 Shipped!
$495 Shipped for just the Injectors!
- Ideal for medium to large size turbos on STi (20G, Green, GT30R, etc.)
- 450 WHP Capable
IHI VF34 Turbo / Helix 660cc WRX Injectors / Walbro Fuel Pump Combo!
$1249 Shipped!
- Includes Turbo, Helix Injectors, Walbro FP
- Includes new gaskets for installation
- A properly setup engine management system is required to maximize the power output of this turbo. We suggest the Cobb Accessport which
we can ProTune or the Ecutek reflash.
- 300WHP capable w/ supporting mods on race gas
- 660cc injectors provide extra headroom over 565cc injectors for race gas
1X Motor:
2.2 Stroker Shortblock - Fully Sleeved: $2299 + shipping!
Custom built for a customer who decided to go with a 2.5 instead. This motor will be able to withstand high hp applications.
*Wiseco Forged Stroker Pistons
*STI Crankshaft / Connecting Rods (all brand new)
*Darton Fully Sleeved
*Fully balanced, professionally installed
*2.2 Final Displacement
Also, we still have one set of the Nismo 740s left if you're looking for something a little smaller.
Nismo 740cc Injectors - $449 shipped (AT COST!!!)
- Actually in stock!
- Ideal for samll to medium size turbos on STi (VF34, 18G, 20G, GT30, Red)
- 385-450 Crank HP Capable
Thanks,
Preston
We Accept Paypal!
product name: XXXX
sales rep: Preston
Shipping address.
- Economical Price
- Easy to tune
$499 Shipped!
- 340WHP Capable
$519 Shipped!
- 450 WHP Capable
$539 Shipped!
- 450 WHP Capable
$1249 Shipped!
1X Motor:
Thanks,
Preston
We Accept Paypal!
product name: XXXX
sales rep: Preston
Shipping address.
Exhausts:
Greddy SP2 Catback- 02+ WRX / 04+ STI
The Greddy SP2 exhaust for the Subaru WRX/STi is one of the quietest exhaust systems on the market. Made from Full Stainless Steel. Full 80mm mandrel bent piping.
$529 shipped!!!
Borla Hush Catback- 02+ WRX / 04+ STI
The Borla Hush exhaust for the Subaru WRX/STi is also one of the quietest exhaust systems on the market. It also features a very stock looking twin-tip design which is always nice if you're not trying to attract attention from the authorities. Made from Full Stainless Steel. Full 80mm mandrel bent piping. Available with 3" downpipe adapter flange at extra cost.
$PRICE TOO LOW TO POST!!!
Helix is back in stock!
Mix and match to create your own packages w/ the above catbacks! Contact us for pricing.
Helix Catted Downpipe: $399 shipped
-Full 3" bellmouth design
-Will pass emissions sniffer test (but not visual inspection)
Helix Catless Downpipe: $285 shipped
Helix TMIC: $599 Shipped
-Ideal for VF34 size turbo upgrades
-Proven to be more efficient than the JDM STi TMIC.
-Proven to make power.
Gruppe-S V2 Headers: $399 Shipped
-Dyno proven to gain HP and TQ
-Full Stainless steel
$529 shipped!!!
Other items:
Helix Catch Can - $75 Shipped
The Helix Catch Can is designed to trap oil moisture and blow-by caused by normal engine operation, especially in turbo charged vehicles. This debris will tend to accumulate inside the intake tract, intercooler, turbocharger, as well as be ingested into the engine during normal combusion process. Needless to say, this sludge and blow-by will hurt the performance of your vehicle.
Gruppe-S Carbon Fiber Radiator Shroud- 02+ WRX / 04+ STI
Approximately 20% of incoming air current is diverted away from the radiator by the radiator support. The radiator shroud reduces this loss, by redirecting airflow over the radiator. The result is an increased cooling efficiency of the radiator. The Gruppe-S Carbon Fiber Radiator shroud is made from high quality dry carbon fiber to insure that it is as light as possible.
$99 Shipped!!!
Gruppe-S Heat Shield- 02-05 WRX
This heatshield will lower your underhood operating temperatures by directing heat from the turbo and downpipe away fromt your TMIC and the rest of your engine. This will in turn lead to more power from cooler intake temperature and better engine operating conditions.
$49 Shipped!!!
Cusco Turbo Heat Shield - 02+ WRX / 04+ STi
This beautiful heat shield from Cusco fits any stock turbo, or most any IHI upgrade turbo. Stainless steel construction means no rust and an attractive underhood appearance. This heatshield will lower your underhood operating temperatures by directing heat from the turbo and downpipe away fromt your TMIC and the rest of your engine. This will in turn lead to more power from cooler intake temperature and better engine operating conditions.
$75 Shipped!!!
Sard R2D2 Blow Off Valve for 02+ WRX / 04+ STi
These unique looking and sounding blow off valves are very popular in Japan. Sard is known for their high quality racing components and this blowoff valve is no different; it utilizes a dual drive type construction similar to the HKS blowoff valve that prevents leaking.
$259 Shipped!!!
We only have a few more VF34s left! So take advantage of the $1199 shipped special while we still have these turbos.
IHI VF34 + STI 565CC Injectors + Walbro Fuel Pump
-375HP Capable on a WRX (with proper tuning)
-Includes Genuine IHI VF34
-Genuine STI 565cc Pink Injectors
-Walbro 255l/h Fuel Pump
$1199 shipped!!!
IHI VF34 + STI 565CC Injectors + Walbro Fuel Pump + Ecutek Reflash
-Send us your ECU and we'll reflash it and we'll overnight it back to you
$1899 shipped!!!
IHI VF34 + STI 565CC Injectors + Walbro Fuel Pump + Installation + Ecutek Reflash + Custom Dynotune
-Please call to schedule an appointment
$2249 shipped!!!
Insane Injector / Fuel Pump Clearance: - All instock and ready to ship!
PE 650cc top feed injectors + Walbro 255L FP and setup kit - $679 Shipped!
$609 Shippedfor just the Injectors!
- Ideal for medium size turbos on WRX (18G-20G)
- 350-435 Crank HP Capable
Next up, we have one twinscroll manifold, uppipe, and downpipe (complete setup kit) for a VF37 or VF36. These are extremely hard to get; we probably only get 1 set of these every 2 months and you need these items to use a VF36 or VF37 turbo.
$999 Shipped
Thanks,
Preston
We Accept Paypal!
product name: XXXX
sales rep: Preston
Shipping address.
$99 Shipped!!!
$49 Shipped!!!
$75 Shipped!!!
$259 Shipped!!!
$1199 shipped!!!
$1899 shipped!!!
$2249 shipped!!!
$999 Shipped
Thanks,
Preston
We Accept Paypal!
product name: XXXX
sales rep: Preston
Shipping address.
Right now for a limited time only, if you provide us with your 2.5L block, get a $500 discount on any of our staged motors!!!
STi 2.5L Shortblock now obsolete? Gruppe-S Staged Motor Packages!
Why pay $1600 for an STI shortblock just to throw in $500 forged pistons, then pay $200 for installation ($2300) when for $299 more you can purchase a Gruppe-S Stage One Shortblock ($2599)?
So you're probably wondering, what exactly do I get for that extra $299?
Well, you also get:
-Race Spec Coated Bearings
-Complete balance of rotating assembly to within 1 gram
-Professional Assembly
Press Release:
Gruppe-S is proud to announce that it now offers complete built motor packages to the general public. A service only available to local customers previously, we have combined the best and most cost effective components available to form staged motor packages that should suit nearly every Suby junkie’s needs. These short and long blocks will support anywhere from 535 CHP to 700 CHP and all provide increased strength, power, and reliability. They are sold as packages so that you, the user, doesn’t have to worry about any options, specifics, or details.
Stage 1:
Not so crazy that it can’t be driven on the street but strong enough to handle almost anything that can be throw at it, the Gruppe-S 2.5 Stage One Motors are designed to reduce the compromise between high horsepower and reliability. Available as either a short block or long block that utilizes either your USDM STi’s AVCS heads or WRX EJ20 heads off of your own motor (includes custom gaskets for proper compression ratios), this motor is essentially a beefed up version of the USDM STi motor. Derived from our extensive experience building and tuning both race and street cars, our Stage 1 eliminates the failure points of the stock STI engine. We have replaced the stock hyper-cast pistons with our custom forged units by Wiseco. Wiseco Pistons were selected due to their versatility for both street and race applications; they eliminate the compromise of a "loose" race piston by retaining a better operating range. The factory bearings have also been replaced with coated race units that eliminate the spun / seized bearing issue we often see in high power applications. The longblock utilizes Cometic gaskets and ARP Head Studs to affix the heads to the block. Finally, the entire assembly is professionally balanced and assembled to race specifications (within 1 gram). When coupled with the lighter forged pistons, the is a redline that has been raised to 7500RPM. We recommend this short-block for all Subaru owners making in excess of 460HP. Can the stock motor hold more power? Yes, but based on our experience building and tuning literally hundreds of Subarus, the reliability of the engine becomes questionable at those power levels.
Assembly time is generally 2-3 weeks. For the Long block option, we require a core charge for the heads which will be refunded if you heads are in good working order.
Features:
-Gruppe-S / Wiseco Forged Pistons
-Gruppe-S Coated High Performance Rod & Crankshaft bearings
-ARP Headstuds (on long-block option)
-Cometic Head Gaskets (on long-block option)
-Professionally balanced rotating assembly (recommended 7500 RPM redline)
-Rehoned cylinder walls
-Capable of up to 535HP Operation
-Final Displacement 2.48L
-Compression ~8.5 : 1
$2599 for short-block
$3099 for long-block (+$1500 core charge)
Stage 2:
The Gruppe-S Stage Two Race Engine is a logical progression from Stage One: it combines our Stage One short block with a treated / reworked crankshaft for high RPM operation. The combination of forged pistons, coated race bearings, proper balancing, and re-worked crankshaft yields a potent short-block capable of supporting a staggering 600HP while also revving to 8000RPM. On the longblock option, Gruppe-S Stage Two camshafts (AVCS on STI), an upgraded valvetrain, and titanium retainers are added for extra breathing ability.
Features:
-Coated High Performance Rod & Crankshaft bearings
-Reworked high RPM crankshaft
-Gruppe-S Stage Two camshafts (AVCS available) (on long-block option)
-Gruppe-S Stage Two Valve Train (on long-block option)
-Professionally balanced and assembled (recommended 8000 RPM redline)
-Capable of up to 600HP Operation
$3299 for short-block
$5499 for long-block (+$1500 core charge)
Thanks,
Preston
preston@gruppe-s.com
510-783-5300
Well, you also get:
Press Release:
Stage 1:
Features:
Stage 2:
Features:
Thanks,
Preston
510-783-5300
Ok,
I know my Hawaii peeps want details. Core is Setrab with thermal dispersant coating. Kit adds approximately 1.25 quarts of oil to engine capacity. Core mounts behind the grill on the left or the right. Should fit most FMICs but depends on height and depth. IMHO the cost to value factor for this kit is the best I've seen. I've already ordered my kit. If any locals want to check it out, it should be here next week. For the cost of a beer (a big can of Fosters) I'll let you leer at it.
San
San
Car Info: 2005 wrx
Originally Posted by j*bishop
any pics of the oil cooler installed preston?
thx
vince
thx
vince
i was going to ask the same thing. how does it mount?
thanks
gruppe-s
Engine and Drivetrain
Mar 29, 2006 04:17 PM
gruppe-s
Nov 22, 2005 06:59 PM
gruppe-s
Nov 22, 2005 06:54 PM
depdivr
Sep 29, 2005 10:52 PM
gruppe-s
Sep 20, 2005 07:08 PM
