Built Motors, Alky Injection, Power Packages, and much much more!
Old Nov 22, 2005 | 06:55 PM
gruppe-s's Avatar
Exhausts:
Greddy SP2 Catback- 02+ WRX / 04+ STI
The Greddy SP2 exhaust for the Subaru WRX/STi is one of the quietest exhaust systems on the market. Made from Full Stainless Steel. Full 80mm mandrel bent piping.
$529 shipped!!!
Borla Hush Catback- 02+ WRX / 04+ STI
The Borla Hush exhaust for the Subaru WRX/STi is also one of the quietest exhaust systems on the market. It also features a very stock looking twin-tip design which is always nice if you're not trying to attract attention from the authorities. Made from Full Stainless Steel. Full 80mm mandrel bent piping. Available with 3" downpipe adapter flange at extra cost.
$PRICE TOO LOW TO POST!!!
Helix is back in stock!
Mix and match to create your own packages w/ the above catbacks! Contact us for pricing.
Helix Catted Downpipe: $399 shipped
-Full 3" bellmouth design
-Will pass emissions sniffer test (but not visual inspection)
Helix Catless Downpipe: $285 shipped
Helix TMIC: $599 Shipped
-Ideal for VF34 size turbo upgrades
-Proven to be more efficient than the JDM STi TMIC.
-Proven to make power.
Gruppe-S V2 Headers: $399 Shipped
-Dyno proven to gain HP and TQ
-Full Stainless steel
Old Nov 22, 2005 | 06:56 PM
gruppe-s's Avatar
Other items:
Helix Catch Can - $75 Shipped
The Helix Catch Can is designed to trap oil moisture and blow-by caused by normal engine operation, especially in turbo charged vehicles. This debris will tend to accumulate inside the intake tract, intercooler, turbocharger, as well as be ingested into the engine during normal combusion process. Needless to say, this sludge and blow-by will hurt the performance of your vehicle.
Gruppe-S Carbon Fiber Radiator Shroud- 02+ WRX / 04+ STI
Approximately 20% of incoming air current is diverted away from the radiator by the radiator support. The radiator shroud reduces this loss, by redirecting airflow over the radiator. The result is an increased cooling efficiency of the radiator. The Gruppe-S Carbon Fiber Radiator shroud is made from high quality dry carbon fiber to insure that it is as light as possible.
$99 Shipped!!!
Gruppe-S Heat Shield- 02-05 WRX
This heatshield will lower your underhood operating temperatures by directing heat from the turbo and downpipe away fromt your TMIC and the rest of your engine. This will in turn lead to more power from cooler intake temperature and better engine operating conditions.
$49 Shipped!!!
Cusco Turbo Heat Shield - 02+ WRX / 04+ STi
This beautiful heat shield from Cusco fits any stock turbo, or most any IHI upgrade turbo. Stainless steel construction means no rust and an attractive underhood appearance. This heatshield will lower your underhood operating temperatures by directing heat from the turbo and downpipe away fromt your TMIC and the rest of your engine. This will in turn lead to more power from cooler intake temperature and better engine operating conditions.
$75 Shipped!!!
Sard R2D2 Blow Off Valve for 02+ WRX / 04+ STi
These unique looking and sounding blow off valves are very popular in Japan. Sard is known for their high quality racing components and this blowoff valve is no different; it utilizes a dual drive type construction similar to the HKS blowoff valve that prevents leaking.
$259 Shipped!!!
We only have a few more VF34s left! So take advantage of the $1199 shipped special while we still have these turbos.
IHI VF34 + STI 565CC Injectors + Walbro Fuel Pump
-375HP Capable on a WRX (with proper tuning)
-Includes Genuine IHI VF34
-Genuine STI 565cc Pink Injectors
-Walbro 255l/h Fuel Pump
$1199 shipped!!!
IHI VF34 + STI 565CC Injectors + Walbro Fuel Pump + Ecutek Reflash
-Send us your ECU and we'll reflash it and we'll overnight it back to you
$1899 shipped!!!
IHI VF34 + STI 565CC Injectors + Walbro Fuel Pump + Installation + Ecutek Reflash + Custom Dynotune
-Please call to schedule an appointment
$2249 shipped!!!
Insane Injector / Fuel Pump Clearance: - All instock and ready to ship!
PE 650cc top feed injectors + Walbro 255L FP and setup kit - $679 Shipped!
$609 Shippedfor just the Injectors!
- Ideal for medium size turbos on WRX (18G-20G)
- 350-435 Crank HP Capable
Next up, we have one twinscroll manifold, uppipe, and downpipe (complete setup kit) for a VF37 or VF36. These are extremely hard to get; we probably only get 1 set of these every 2 months and you need these items to use a VF36 or VF37 turbo.
$999 Shipped
Thanks,
Preston
Phone: (510) 783-5300
We Accept Paypal!
Paypal: sales@gruppe-s.com
When ordering w/ paypal, please include the following:
product name: XXXX
sales rep: Preston
Price including shipping: $XXXX
Shipping address.
Old Nov 22, 2005 | 06:57 PM
gruppe-s's Avatar
We've got a new product that we're really excited about: SMC Alcohol Injection. It's got a ton of potential but it's still a very cost effective mod. Designed to be a hassle free upgrade, this package includes everything you need to get alcohol injection running properly on your car. Although many people are “scared” of alcohol injection, if utilized properly, it is perfectly safe while also being one of the best bang for the buck power adders available for a boosted car. Alcohol injection works by injecting a fine mist of alcohol into the intake stream. This does two important things:
1) Alcohol Injection lowers the temperature of the intake charge to create a denser (and thus greater) air mass.
2) Alcohol Injection raises the effective octane of your fuel which works towards avoiding detonation (the sworn enemy of engines).
These two factors are particularly beneficial on turbocharged cars because the effectiveness of turbocharging is dependent on having a dense and cool intake charge while also avoiding detonation. Boosted engines are particularly succeptable to detonation because they can see such high pressures and temperatures. By increasing the effective octane of your fuel, it allows you to run higher boost and add more timing advance. It is not uncommon to see HP gains as high as 20-30% with these changes, regardless of modifications. Additionally, two added bonuses of alky injection are that it also cleans your engine and will work with pump gas.
*Dyno graph taken from 2.35L running GT35R w/ supporting mods.
The SMC Alcohol Injection System is unique, reliable, and safe in several regards. Designed from the ground up specifically for the Subaru WRX and STi, this system includes a 1 gallon washer fluid tank that serves as a reservoir. This makes for a very simple and stealthy install. A small auxilliary washer tank/pump that mounts in front of the battery is also included so that you can still clean your windshield. Another unique feature of this kit is the Progressive Controller. An extremely small unit that can be fitted nearly anywhere (it measures only 2.75" wide x .9" high x 4.6" deep), this microprocessor based device will automatically increase alcohol spray pressure as boost rises. This system runs on denatured alcohol that can be bought nearly anywhere.
As is wise when running high boost levels, tools critical to tuning are highly recommened to be used in conjunction with this kit. A wide-band 02 controller, knock link, and tuning are suggested.
- Increase effective octane of fuel
- Drastically decrease temperature of intake charge
- Allows higher boost and more timing advance
- Expect 20-30% HP increases
- Stealth installation
SMC Alcohol Injection - $499 Shipped!
We are offering the following packages:
SMC Alcohol Injection + Link Knock Link + PLX M300 Wideband - $1099 Shipped!
This combo includes everything you will will need (short of EM) to tune and safely run alky injection on your car. When running at high levels of boost, it is absolutely critical to monitor knock so that your engine doesn't blow itself up. The PLX wideband is one of the best on the market and will ensure that you are running at optimum AFRs.
SMC Alcohol Injection + Cobb Acessport + Link Knock Link + PLX M300 Wideband - $1649 Shipped for WRX!
$1699 Shipped for STi
This combo includes everything you will will need (including EM) to tune and safely run alky injection on your car. When running at high levels of boost, it is absolutely critical to monitor knock so that your engine doesn't blow itself up. The PLX wideband is one of the best on the market and will ensure that you are running at optimum AFRs. Finally, the Cobb AP is argualbly the most versatile engine management solution on the market allowing for multiple map capability and full control over the ECU's parameters. You will need a Protune with this setup.
Other tuning solution packages:
If you consider your engine a worthwhile investment (which I think most of you do), you might want to consider this little insurance policy:
An extremely valuable tuning tool and problem indicator, the Link Knock Link w/ Bosch Knock sensor is a critical component for the highly modified engine. Highly modified engines run the thin line between peak power and engine failure. This failure is often caused by detonation. The Knock Link uses a highly sensitive (and superior) to stock) Bosch knock sensor that is extremely sensitive to detonation. The Knock Link alerts you the moment detonation is occurring; not after you've finished looking at your data logs or blown your motor. The Knock Link can protect your motor while tuning or simply when you get a bad tank of gas. It is our opinion the Knock Link belongs right next to the Wide Band O2 sensor and is a necessity for the highly modified engine; think of it as cheap insurance to protect your high performance (and expensive) motor.
-Monitor real-time knock.
-Optimise advance.
-An excellent saftey measure for heavily modified engines
We are offering the following package:
-Cobb Accessport
-1 Custom Map for your car tuned by Mike (must be standard bolt on modifications)
-Link Knock Link
-Bosch Knock sensor
-Installation
$1099 OTD (includes tax!) for WRX
$1149 OTD (includes tax!) for STi
$249 Shipped for just the Knock Link and Sensor
Thanks,
Preston
preston@gruppe-s.com
510-783-5300
Old Nov 22, 2005 | 06:59 PM
gruppe-s's Avatar
STi 2.5L Shortblock now obsolete? Gruppe-S Staged Motor Packages!
Why pay $1600 for an STI shortblock just to throw in $500 forged pistons, then pay $200 for installation ($2300) when for $299 more you can purchase a Gruppe-S Stage One Shortblock ($2599)?
So you're probably wondering, what exactly do I get for that extra $299?
Well, you also get:
-Race Spec Coated Bearings
-Complete balance of rotating assembly to within 1 gram
-Professional Assembly
Press Release:
Gruppe-S is proud to announce that it now offers complete built motor packages to the general public. A service only available to local customers previously, we have combined the best and most cost effective components available to form staged motor packages that should suit nearly every Suby junkie’s needs. These short and long blocks will support anywhere from 535 CHP to 700 CHP and all provide increased strength, power, and reliability. They are sold as packages so that you, the user, doesn’t have to worry about any options, specifics, or details.
Stage 1:
Not so crazy that it can’t be driven on the street but strong enough to handle almost anything that can be throw at it, the Gruppe-S 2.5 Stage One Motors are designed to reduce the compromise between high horsepower and reliability. Available as either a short block or long block that utilizes either your USDM STi’s AVCS heads or WRX EJ20 heads off of your own motor (includes custom gaskets for proper compression ratios), this motor is essentially a beefed up version of the USDM STi motor. Derived from our extensive experience building and tuning both race and street cars, our Stage 1 eliminates the failure points of the stock STI engine. We have replaced the stock hyper-cast pistons with our custom forged units by Wiseco. Wiseco Pistons were selected due to their versatility for both street and race applications; they eliminate the compromise of a "loose" race piston by retaining a better operating range. The factory bearings have also been replaced with coated race units that eliminate the spun / seized bearing issue we often see in high power applications. The longblock utilizes Cometic gaskets and ARP Head Studs to affix the heads to the block. Finally, the entire assembly is professionally balanced and assembled to race specifications (within 1 gram). When coupled with the lighter forged pistons, the is a redline that has been raised to 7500RPM. We recommend this short-block for all Subaru owners making in excess of 460HP. Can the stock motor hold more power? Yes, but based on our experience building and tuning literally hundreds of Subarus, the reliability of the engine becomes questionable at those power levels.
Assembly time is generally 2-3 weeks. For the Long block option, we require a core charge for the heads which will be refunded if you heads are in good working order.
Features:
-Gruppe-S / Wiseco Forged Pistons
-Gruppe-S Coated High Performance Rod & Crankshaft bearings
-ARP Headstuds (on long-block option)
-Cometic Head Gaskets (on long-block option)
-Professionally balanced rotating assembly (recommended 7500 RPM redline)
-Rehoned cylinder walls
-Capable of up to 535HP Operation
-Final Displacement 2.48L
-Compression ~8.5 : 1
$2599 for short-block
$3099 for long-block (+$1500 core charge)
Stage 2:
The Gruppe-S Stage Two Race Engine is a logical progression from Stage One: it combines our Stage One short block with a treated / reworked crankshaft for high RPM operation. The combination of forged pistons, coated race bearings, proper balancing, and re-worked crankshaft yields a potent short-block capable of supporting a staggering 600HP while also revving to 8000RPM. On the longblock option, Gruppe-S Stage Two camshafts (AVCS on STI), an upgraded valvetrain, and titanium retainers are added for extra breathing ability.
Features:
-Coated High Performance Rod & Crankshaft bearings
-Reworked high RPM crankshaft
-Gruppe-S Stage Two camshafts (AVCS available) (on long-block option)
-Gruppe-S Stage Two Valve Train (on long-block option)
-Professionally balanced and assembled (recommended 8000 RPM redline)
-Capable of up to 600HP Operation
$3299 for short-block
$5499 for long-block (+$1500 core charge)
Thanks,
Preston
510-783-5300
gruppe-s
Engine and Drivetrain
Jul 5, 2006 04:11 PM
gruppe-s
Mar 7, 2006 02:46 PM
gruppe-s
Dec 17, 2005 10:27 AM
gruppe-s
Nov 22, 2005 06:54 PM
