Power Steering problems
Old Aug 9, 2004 | 08:03 AM
wvjnky's Avatar
Car Info: 02' Black Wgn
My power steering is all jacked up. When just sitting at idol, I get no power assist (except when the motor is cold). When I bring the RPM's up I seem to get some assist then when the car is just coasting I get little to no assist. Anybody got any ideas? It seems that the pump is whinning a little as well?????????? Thanks for the help.
Old Aug 9, 2004 | 02:36 PM
RoadSpike's Avatar
Not to state the obvious but is your fluid low?
Old Aug 10, 2004 | 01:51 PM
wvjnky's Avatar
Unhappy Not at all.
I just got back from subaru and they told me that the pump is bad. They have never seen this before but the impeller that pushes the fluid isn't spining at the right revs hence not suppling the rack with enough line pressure. Just my luck I guess. The fun thing is the $400 dollars to get the new pump. Yeah for me!!!!!
Old Aug 13, 2004 | 05:03 PM
My_Red_Suby's Avatar
Car Info: 2005 Metallic Gray STI
Bad pump?
Yep u definitely have a blown power steering pump. You should get it fixed before it gets really bad. I had the same problem before and I didn't get it fixed right away and as a result tiny metal pieces got into the whole power steering pump system.
Marky
Old Aug 13, 2004 | 11:51 PM
RoadSpike's Avatar
Is you car relatively new? Can you just have it fixed under warrenty?
Old Jan 29, 2005 | 11:15 AM
BeE_JiZZeLs's Avatar
Car Info: bugeye WAR wagon
i know this is an old post... but what happened? i've got sort of the same problem... power steering=non existant. did u get it done under warranty?
long6gauge
Feb 21, 2013 10:04 AM
Hermanbaggins
Feb 12, 2013 05:32 PM
grex767
May 27, 2006 10:37 AM
dyepball1
May 18, 2006 10:23 AM
TheREAL HiFiWRX
Oct 22, 2004 03:55 PM
