new clutch, 5 speed shifting poorly - help
Old Oct 1, 2004 | 11:06 PM
LMON50's Avatar
Car Info: 2002 WRX Wagon
sorry aaron, i don't have a tip for you but rather a question. i too have a 96 brighton 2.2 and my throw out bearing can now be heard so i'm heading in the direction of a new clutch; even though it's not slipping yet. which clutch kit did you go with and what were the associated costs?
thanks
Old Oct 26, 2004 | 11:38 AM
SUBARU_TECH's Avatar
shifting woes
first make sure that the cable is adjusted properly.if you need that info i would be glad to send it.also does your car have the hill holder option.if you are unsure,check to see if you have a seperate cable going to the release fork.also check if the gear box will shift correctly without the engine running.
blue blurr
Jun 22, 2006 02:53 PM
NJ Dino
Feb 13, 2005 10:22 AM
burmis1
Oct 15, 2004 05:31 AM
albertcrothers
Jul 27, 2004 07:07 AM
