!HELP! Installed my clutch fu#@er won't work!!!
Old Nov 3, 2003 | 06:59 AM
TecHniKa's Avatar
Car Info: 02 wrx R.I.P.
Angry !HELP! Installed my clutch fu#@er won't work!!!
I just finally got my car back together,I installed a new clutch disc,pressure plate,throwout bearing,and faced my flywheel.I tried to start it and it sounds like someone sticking something in the spokes of a bicycle.Also when I press in the clutch it's real light and doesn't have any pressure to it.I spent my whole weekend off working on it just to have it not work.If anyone could give me some info that would be great.Then I can stop pulling my hair out and hitting myself in the head.
Old Nov 5, 2003 | 04:34 AM
TecHniKa's Avatar
Allright...found the problem,the damn dust shield was bent when I installed the tranny,so when the pressureplate would spin it would rub against that beeoch.So I took it all the way apart again,just to find that out.now I have it all the way back together.I go to start it and it cranks up,for 1 second then stops.So thats the new problem.While I had the tranny out the first time I figured that it would be easy to install a upipe.It only took a little while to do but when putting back the senser in the up pipe I broke it when trying to bend it to fit in there.Just the little needle like piece that went inside the nasty stock upipe.Other than that me and my friends cannot figure this one out.Every thing sounds great but it won't stay running.Any help would be great if anyone has some experience working on wrx's,I know its only a select few.
Old Nov 5, 2003 | 12:40 PM
Chibby Goku's Avatar
Car Info: Vakamon WRX
Good news!
Recheck your connections, ie. intercooler hoses, butt plugs,...
Old Nov 6, 2003 | 09:41 AM
TecHniKa's Avatar
Well allready found the problem.I custom made a short ram intake and welded the maf mount on backwards.So I put the stock air box back on and it cranked right up.But the new problem is that now I have a broken transmission,with a new clutch. !!Oh yeah Chibby Goku you might want rethink your benign replies, because I am too immature and ignoarant to ignore what I perceive to be a personal slight from someone I have never met before, thereby causing me to rant and rave like a stubborn child.
Old Nov 7, 2003 | 02:51 AM
IS2Scooby's Avatar
Pr0n King
Car Info: Turncoat Turbo
Originally posted by TecHniKa
Well allready found the problem.I custom made a short ram intake and welded the maf mount on backwards.So I put the stock air box back on and it cranked right up.But the new problem is that now I have a broken transmission,with a new clutch. !!Oh yeah Chibby Goku you might want rethink your kindergarden replies,and your mom told me to tell you to pull her ***** out of your *** BEEEOOOCCCHHH!!!!!!!!!!!!!
WTH? What a jerk!
__________________
Old Nov 7, 2003 | 03:14 AM
I like cheese.
Old Nov 7, 2003 | 03:30 AM
And bananas. :banana: :banana: :banana:
Old Nov 7, 2003 | 03:36 AM
Why Subaru don't hatchback?
Old Nov 7, 2003 | 07:19 AM
TecHniKa's Avatar
W3rd. And grap on my tired? Wth does that mean anyway?
Old Nov 7, 2003 | 12:11 PM
gpatmac's Avatar
Hey, any of you guys seen the picture of the STi in the lake?
Old Nov 7, 2003 | 12:13 PM
IS2Scooby's Avatar
Pr0n King
*shakes head*
Dude, that's so old, there was only one I-club when that was posted.
__________________
Old Nov 7, 2003 | 01:18 PM
mmboost's Avatar
Hey what about that fuzzy little brown puppet? What's his deal?
Old Nov 7, 2003 | 05:46 PM
namakemono's Avatar
Car Info: gc w/ neons and a wrx that needs neons
I dunno. But I like cheese. And bananas too.
:banana: :banana: :banana: :banana: :banana: :banana: :banana: :banana: :banana: :banana:
Old Nov 7, 2003 | 08:46 PM
Are we green here fellas?
Alliedforces86
Nov 21, 2009 08:20 PM
03_Impreza_Al
Nov 16, 2006 10:42 PM
British Banger
Jul 19, 2003 04:09 PM
AWDball
Dec 17, 2002 12:07 PM
