Why won't this Stinkin' VF35 work? I need help fast!
I cannot get this thing to work with my setup.
When I drive it the boost goes straight to 19 psi it doesn't really "creep" it actually goes right to 19 lbs when i hit about 4000 to 4500 rpm.
If you have a similar setup with the same turbo, or have advice, please help me.
Trey Cobb told me that the reason it is not working properly is because there is not enough back pressure so the wastegate will open up. That is why I didn't think it was the boost controller. Ket me know if I am wrong, please.
here are a few questions:
Are you using the stock exhuast, or a different exhaust (I am using the M2 turboback)? And if you are using the stock exhaust what do your EGT's look like? I am afraid of them being too high.
What we did is I tried running with the wastegate wide open ( disengaged the wastegate actuator) and it still boosted to 15lbs. It takes longer to come up to 15 but it still boosts when it should not. Please help me please!!!
Ka24de
Aug 9, 2004 10:03 PM
