Engine and tranny stuck together??
Old Apr 30, 2006 | 03:36 PM
bluebiker's Avatar
Car Info: 2002 Subaru Impreza WRX - WRB
I am in the later stages of an sti engine swap...
Except I cannot get my Tranny removed from the engine.
I have unbolted the 6 Bolts, and 2 Nuts... And jacked up the trans, and hoisted the engine... Shaking, pulling, etc... And cannot get them to even seperate a mm.
(I am free of the motormount bolts on the crossmember... so i can't find out what the hell is wrong)
ANY ADVICE?? Ways this has worked for you?
Thanks.
I read this post, but there was no solution.
https://www.i-club.com/forums/showth...ission+removal
Old May 1, 2006 | 09:35 PM
Keisatsu's Avatar
Car Info: Broken ass stock '02 WRX
Hmm, my only suggestion is DON'T use a crobar (sp?) to get them apart, my buddy did that w/ his charger and fawked everything up!
Old May 1, 2006 | 09:39 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
You did not remove the clutch fork. You need to push the tranny back onto the engine, then use 12mm allen to remove the clutch fork rod plug, then use a long 10mm bolt to screw it into the end of the rod and slide the rod out. Then the engine and tranny will come apart...
Old May 1, 2006 | 09:41 PM
de pilipino guy's Avatar
Car Info: none
what he said....located on top of the tranny towards the driver side...it's pretty close underneath the starter(i think)...
Old May 2, 2006 | 05:14 AM
Toiletbrush's Avatar
Car Info: '94 WRX, '97 Forester S/Tb, '95 WRX-RA
Get to ordering a new throwout bearing now so you have it when you need it. Chances are, the tabs on the bearing are pretty bent or cracked if you fought to remove the tranny without removing the fork first. (Prior experience.)
Old May 20, 2006 | 06:06 AM
bluebiker's Avatar
got it.
thanks guys. I was able to get it apart with your advice!
SFO GTO
Mar 5, 2010 02:02 AM
zphreak
Aug 6, 2007 05:23 AM
annointed
Subaru OEM Parts For Sale
Jul 21, 2005 02:32 PM
NJ Dino
Apr 28, 2005 09:33 PM
johnkaldar
Apr 21, 2005 02:46 PM
