Help - Pulling engine and I'm stuck - 03 WRX Wagon
Old Jul 17, 2007 | 02:55 PM
zphreak's Avatar
Car Info: 02 Wagon
I spun a rod bearing at the end of March and picked up a used 2005 EJ20 long block. Well I have everything done except pulling the shifter fork rod. I can't the thing out no matter what I do. I just moved to Elk Grove and need to get my car back on the road ASAP as my daughter will be starting school soon and putting her on my motorcycle just isnt' an option.
Anyone have some spare time to stop by and give me a hand? Beer and pizza will be provided (beer after of course ). I'm in Elk Grove off Laguna Blvd.
Old Jul 17, 2007 | 03:20 PM
vietpunk916's Avatar
Car Info: AP1 S2k
Welcom to i club! There would be many people who would help u out in this situation, but im not one of them. Not trying to say that im that type of person but i just dont know **** about mechanical parts lol. If all goes wrong or u have nobody else, call paul at dbtuned, his shop is in roseville. =D
Old Jul 17, 2007 | 03:29 PM
jvick125's Avatar
Car Info: Sline
But good luck getting it there without an engine.
Old Jul 17, 2007 | 03:36 PM
sybir's Avatar
Warm Fuzzy Admin
They make things called tow trucks. Hell of an invention.
Old Jul 17, 2007 | 03:37 PM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
Tow trucks have been available for , oh, I don't know, 100yrs.
You need a 12mm socket, an extension, and a 12mm wrench.
Old Jul 17, 2007 | 03:44 PM
jvick125's Avatar
Car Info: Sline
minor details.
Old Jul 18, 2007 | 02:00 AM
Car Info: AP1 S2k
you guys are ***** lol.
Old Jul 18, 2007 | 07:49 AM
zphreak's Avatar
Car Info: 02 Wagon
6mm bolt into fork shaft done but the shaft doesn't slide out.
Like I said, everything else is disassembled.
Old Jul 18, 2007 | 07:57 AM
ipozestu's Avatar
Car Info: Broken Subarus
Get the cherry picker hooked up, take some of the weight of the engine remove all of the bolts holding the tranny to the engine and give the engine a wiggle as you pull on the shaft. It'll come out
Old Jul 18, 2007 | 08:17 AM
iClub Silver Vendor
OK.
1stly...that's the clutch release bearing fork. Thought you were talking about the shifter input shaft at the rear of the tranny.
With the bolt screwed into the pivot shaft, use a long handled screwdriver or preferably, a pry bar, and pry the bolt out.
It's difficult, but it will come out.
Old Jul 18, 2007 | 08:28 AM
zphreak's Avatar
Car Info: 02 Wagon
Thanks, I'll give that a try this weekend.
Old Aug 5, 2007 | 09:44 PM
zphreak's Avatar
Car Info: 02 Wagon
FYI - pry par did the trick
Engine is removed and new engine is sitting in the compartment while I try to match up the transmission shaft and the engine.. as well as the lower 2 studs into the bell housing.
Old Aug 6, 2007 | 05:23 AM
Irrational X's Avatar
plays well with others
Car Info: your mother crazy
OK.
dont forget the next step:
insert into vahine
Cynt
Aug 13, 2007 02:27 PM
Jizzo_02SubiWRX
Jun 12, 2006 07:50 PM
bluebiker
May 20, 2006 06:06 AM
nuke
Oct 16, 2004 04:38 AM
JamesIV
Jun 24, 2003 12:47 PM
