03 wrx 1st gear problem
Old Aug 27, 2003 | 01:50 AM
teck7droid's Avatar
Car Info: 03 pearl black wrx
Hi, i ran a search and came up with some info on my question but i want to know a bit more. I have 10,000 miles on my car and just recently my Wrx doesnt want to shift into first gear from a complete stop at red lights. Its happend like 4 times in 2 weeks so far.Its really annoying, i engage the clutch fully, The only abuse on the tranny is one 4k rpm launch i didnt even drop the clutch, just a quick release and that was around 2k miles ago. I hope the problem doesnt persist, what can i do to fix it, Should it take into the dealer mabye they will fix it b/c of warrantee My mods include mostly suspensiion progress spring, cusco front and rear sway bars and a custom made stright pipe axel back. please help!
Old Aug 27, 2003 | 01:59 AM
Sounds like a bad synchro. From your description of things, it should be covered.
Old Aug 27, 2003 | 02:04 AM
teck7droid's Avatar
Oh, i see. I wonder why the 1st grear syncro went bad? I hope its not b/c of my driving. I drive really smooth shift 95% of the times at 3k and always get out of 1st really smooth with out over reving. So that wouldnt make sense. I guess ill have to take it to the dealer to have them replace it. I hope they dont ***** and try to not cover me cause that would suck alot.
Old Oct 3, 2003 | 10:12 PM
ASpec818's Avatar
Car Info: Audi B6 S4
did they replace your first gear?
Old Oct 16, 2003 | 10:41 AM
jasno999's Avatar
Car Info: Blaze yellow WRX 2002
They better cover that for you. The car is a sporty car. It is meant to be driven. ANd they better nto give you and crap.
Old Oct 17, 2003 | 06:29 AM
GR8-WRX's Avatar
Car Info: 2010 370z Roadster, 2008 Frontier CrewCab
Originally posted by kevster
I have only 4800 miles on my 03 Wrx and sometimes my trans does the "I do not wanna go into first", so I just slide it into 2nd than into first works every time, I think it is the way the trannys are designed.
I've always done this too in all the MT cars I've had. I haven't noticed any problems going into 1st on my '03 WRX, but I've always had the habit of doing what kevster has described.
Old Oct 27, 2003 | 08:42 AM
wrxpsi's Avatar
Car Info: 06 Steel WRX
Change your fluid! I have an 03 , had that intermittent "will not go into first'. Its seems a common issue with the subes.Synchros just hangs up.Most of the top tuners changed to synthetic fluid.I used Neo Synthetic gear oil.It was a night and day difference ,much smoother engagement,lessened the noise,I have'nt had an issue for 4k miles. Now obviously If you abuse your tranny often then you're going to get wear and tear!
sypher66
Jun 7, 2008 09:59 PM
Keisatsu
Jan 12, 2007 10:40 AM
UCDgogie
Jul 17, 2006 05:06 PM
SubeCal
18
Jun 17, 2003 08:48 PM
