Car problem help*** question..
Old Jan 29, 2012 | 10:28 AM
CaliSuby's Avatar
Unhappy Car problem help*** question..
Turn car this morning to go to wrk and everything seem fine.. Ge on the highway and I get no boost past the "0" on my oem boost gauge... Everything seems fine just no boost?.?.?.? Any suggestions tO what I should look for?
Old Jan 29, 2012 | 10:49 AM
scoobie8's Avatar
Car Info: 2004 WRX PSM WAAGONE & 1967 vee dub squareback
Limp mode? Reset your ecu and check your lines going into the turbo, I had one that had a tear in it on the way to Tahoe one time. I had the same problem, no boost. Mine tore by the plastic tee.
Old Jan 29, 2012 | 11:08 AM
Heedz's Avatar
Nobody likes the tuna here
Wait, Confused here. Is your gauge just not reading correctly or is your car not hitting boost and your gauge is reading that youre not getting any boost either?
I'd start by checking any pressured line. ECU reset also. No CELs?
Old Jan 29, 2012 | 11:48 AM
CaliSuby's Avatar
YouTube - Broadcast Yourself.
Video showing my boost...
Better video engine shot..
Old Jan 29, 2012 | 11:51 AM
CaliSuby's Avatar
No boost.. Gauge is reading it. There was actually a ground cable under my boost control that was loose.. Tighten it and now seems fine.. But I just drove it around the block since I'm at wrk.. I also reset my ecu...
Old Jan 29, 2012 | 12:00 PM
FRAWSTI's Avatar
Car Info: Bagged 2014 STi
I wonder if your exhaust rattled it loose ?
Old Jan 29, 2012 | 12:08 PM
Heedz's Avatar
Okay that plug looked to me like an EGT or o2 sensor plug. the second blue one not sure. You may have all the hoses connected but you may be experiencing a leak because the rubber has gone through, any abnormal whistling noises? I'd also check everything from your filter to turbo for any loose fitting on the couplers. Looked like you slightly boost but maybe a psi or 2. Do you hear your wastegate open any earlier? kinda hard to tell but if thats the case trace that back.
Old Jan 29, 2012 | 12:25 PM
CaliSuby's Avatar
That ground has nothing to do with it you think?
Old Jan 29, 2012 | 12:26 PM
Heedz's Avatar
Wouldn't have a clue unless you traced it back. But atm no? You probably would have more issues. or idling roughness.
Old Jan 29, 2012 | 03:03 PM
MonsterGC's Avatar
Car Info: 2000 2.5rs
hmm check all your injector plugs, the one near the engine side you held is similar to those
then vacuum leak, exhaust leak before turbo?
Old Jan 29, 2012 | 05:27 PM
CaliSuby's Avatar
Yeah the injector plugs are in place ... Will see when I drive home tonight
1wrx2goplz
Feb 9, 2005 09:14 AM
AWD 20T
Nov 12, 2003 03:28 PM
PhreeZe
Jan 28, 2003 12:18 AM
