Aftermarket Forced Induction - Turboed factory NA engines Turbo EJ25! Who said that all Subarus are created equal? Aftermarket turbochargers on factory normally-aspirated engines (factory turbo engines have their own forums).
Help! turbo problems
Old Mar 11, 2006 | 02:46 PM
Dynapar's Avatar
last night i threw my turbo kit on, and well it idled well and work pretty good tell igot about 1/3 of the way home (2 miles or so) and my car died. the tach just dropped to zero. this has happened at one instance a few days prior to going turbo. that day i was climing a slushy hill, and had al 4 spinning. at that moment eh car would die. now when it dies, if i get kick it forward to start it the starter will engage and spin. but nothign will happen (ie starter going nuts, and no starting) if i returnt eh key to the very first position and try starting it, it wil start, but then it will die just like before. if i wait long enough, when i try and start it, it will run.
this problem only seems to occur at low speeds, it happened 2x at a stop, and 1x going 20 mph.
car specs:
95 impreza LX 2.2l AWD Auto
Rallitek PP SMT6
Legacy Turbo injectors
WRX TMIC
Deadbolt rebuit and P&P td04
Cone filter
atmosperic BOV
Helix 3" catless DP
Custom 2" uppipe
innovative motorsports wideband standalone sensor (replaced OEM 1st o2 sensor)
any ideas? advice tips? the car does have a CEL on, but it normally does. tomorow i am gonna scan it for further clues, since its 545 am. a few things that i think may be wrong with it:
overheating
Bad connections
Wiring fault on Piggyback (especially ignition part)
poor airflow to intake sensors
rear o2 sensor (plug maybe connected wrong)
got some new info! CEL is for the crankshaft positioning sensor, circuit malfuntion. there was also a code for the front 02 sensor which is the one i replaced with the wideband, but i did not correctly calibrate the sensor so i think that will fix that problem.
so i am wondering what up with the Crank sensor. did my sensor just take a flop? a loose conection? or perhaps something is the issue with the wiring i did to control timing with the PP6, since i needed to route the crank sensor signal through it inorder to alter the timing.
thoughts? any?
a1rush
Feb 8, 2007 06:43 PM
-WickedRex-
Dec 18, 2006 06:57 PM
sLeak
13
Jun 8, 2006 03:51 PM
grex767
May 27, 2006 10:37 AM
cal_choi
Sep 15, 2003 10:06 PM
